squeeze out
I pump enough to get squeeze out plus a little more to see some clean grease.
"just six squirts"
I wounder are all guns the same? Do they all put out the same amount? I find
it hard to believe all grease guns are calibrated unless you check like Roberta
did. I did not know it was 1 oz.
Than they say, "frequently this will not be be enough to cause any grease to
come out the opposite side."
Sounds like we are OK to get squeeze out. I just go slow and try and
pressurize it.
Not much grease "evaporates" between fillings, so eventually you'll get
squeeze out after a few servicing. I get flow thru with less the 6 pumps, as I
recall.
I guess this is a like a cutting job that calls for an Ax, not a laser. They just
don't want you to try to cram as much as is physically possible in the hub.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
