Dynon Autopilot wont Climb or Decend
Has anyone else had this problem? I have the Skyview system with the Dynon autopilot servos. The pitch servo will hold altitude, but will not climb or descend to a set altitude. For example, if I am at 6k ft and I dial in 8k feet, it will just continue to hold around 6k, maybe creep up or down 100 ft or less. Now the weird part is if I set pitch to rate of climb instead of altitude, it will climb and descend then. Any ideas?
Matt Giordano Sr. and Jr.
RV-8 - N861MM
Wilmington, DE
