Call Boeing for advice, perhaps?
If you're out of warranty, you could search around on the web for how to make an electromagnet with a coil of wire and AC current. I imagine that you can scale the size of the coil and perhaps even the current if you're really brave.
Also note that the pattern of application of the magnet seems to matter -- I had much better luck with rapidly applying and removing the magnet to the affected areas.
