Originally Posted by LAMPSguy
It is caused by a rolling shutter (think the way your TV scans the image). The pixels in the CMOS sensor are recorded the same way. One sure fire way to eliminate it is to record only with CCD based video cameras that use a global shutter (all at once).
There are drawbacks and positives for both types.
The original question was why a ND filter will reduce the rolling shutter artifacts.
Yes, a CCD chip is better for videoing aircraft. Unfortunately, all the compact HD point-of-view cameras I've seen use a CMOS chip (GoPro, Drift, Contour, etc). I have a ten year old Canon DV CCD camcorder that records a very nice prop disc. But after shooting a Drift HD camera I just can't go back to standard definition.
