Old 09-11-2012, 08:47 PM
Michael Burbidge Michael Burbidge is offline
Default Primer port, brass or steel plug?
I'm removing the primer system from my used engine. Should I use brass or steel plugs to fill the ports?
Why?
Michael
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 09-11-2012, 09:14 PM
rv9aviator rv9aviator is offline
I'm interested in knowing if there is a reason not to use brass plugs. I used brass plugs in my engine with a light coating of tite-seal. Brass plugs are used extensively in the die casting trade where I make my living and are subjected to more heat than an engine. The only question I would have is in their use in aluminum as all my usages are in tool steel.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 09-11-2012, 09:18 PM
paul mosher
Posts: n/a
Default Brass
Brassssssssssssssss
Old 09-11-2012, 09:55 PM
chaskuss chaskuss is offline
Default Not the best idea for use with aluminum
Brass and aluminum create a battery. Not a great idea for prevention of galvanic corrosion. See
http://www.eaa1000.av.org/technicl/c...n/galvanic.htm
My answer to Michael's original question would be "None of the Above". Use aluminum AN913 style plugs. See
http://www.aircraftspruce.com/menus/ha/an_plug.html
Charlie
Old 09-12-2012, 06:23 AM
Thanks for the info. I sure hope the tite-seal insulates the brass from the aluminum. I'll pull a couple out at the next condition inspection to make sure there is not a problem.
Jim Wright
Old 09-12-2012, 08:47 AM
az_gila's Avatar
az_gila az_gila is offline
Smile Parts are parts...
You could use the real Lycoming part # 1102 at a whopping $1.28
http://www.aeroinstock.com/products/...ail/index.html
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-12-2012, 09:42 AM
aerhed aerhed is offline
Don't panic Jim, all the injectors, temp sensors, and primer fittings are brass.
Actual repeat offender.
