09-11-2012, 08:48 AM
Dynon and Polarized sunglasses...
Found a pair of glasses I like, however, they are unfortunately polarized.
Anyone wear polarized goggles and have any issue with a Dynon efis?
*EDIT*
Maui Jim Black Coral's are fine with Dynon EFIS's..
09-11-2012, 08:59 AM
polarized sunglasses
I can't see my Dynon with polarized sunglasses. I thought it was just me.
09-11-2012, 09:43 AM
Well, that's a bummer..
09-11-2012, 09:47 AM
Same here. I finally decided to treat myself and buy those $180 Ray Bans. And I cannot use them while flying. UGH.
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
09-11-2012, 09:50 AM
No problems for me with Skyview.
Ipad1 in portrait mode is not good with polarized lenses.
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
09-11-2012, 09:56 AM
From the FAA:
"POLARIZATION. Polarized lenses are not recommended
for use in the aviation environment. While useful for blocking
reflected light from horizontal surfaces such as water or
snow, polarization can reduce or eliminate the visibility of
instruments that incorporate anti-glare filters. Polarized lenses
may also interfere with visibility through an aircraft windscreen
by enhancing striations in laminated materials and mask the
sparkle of light that reflects off shiny surfaces such as another
aircraft?s wing or windscreen, which can reduce the time a pilot
has to react in a ?see-and-avoid? traffic situation."
From the Aviation Safety Letter (Canada):
"Polarized lenses are
great for fishing, but bad for flying. Due to
manufacturing stresses, there
may be small areas of
polarization in an aircraft canopy
or windscreen and, if the angles
of polarization in the glasses and
the windscreen differ, a blind
spot can be produced.
Polarization may also interfere
with depth and distance perception,
particularly during a bank.
Just what you need turning on
final!"
So... be advised.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
09-11-2012, 10:04 AM
Originally Posted by vlittle
From the FAA:
final!"
So... be advised.
Yeh, this is why I asked, due to the readability of some instruments.
09-11-2012, 10:05 AM
"Polarized lenses are not recommended
for use in the aviation environment. .
Can I file a complaint against the term "Polarized Aviators" then
Rick from Fresno
RV-7A
09-11-2012, 10:35 AM
Try the non polarized Serengeti Velocity Drivers Gradient Sunglasses (Aviator).
They work good and I can definitely see my Dynon's
Nigel
RV9A-N113SQ
52F
09-11-2012, 10:55 AM
Those of you who need to wear prescription sunglasses, be sure to specifically ask for tinted lenses. Most places will usually do polarized lenses by default, at least the ones I've encountered.
