Old 09-10-2012, 05:35 PM
Ron B. Ron B. is offline
Default Screw extractor
I'm wandering if the paint cutters from ACS used to remove painted screws actually work and are worth purchasing? ACS P/N 12-02456 for example.
Thanks Ron
Old 09-10-2012, 05:38 PM
krw5927 krw5927 is offline
Thanks Ron
They don't remove the screw but they do cut the paint nicely so that in the process of removing the screw it doesn't take out a chip of paint beyond the screw perimeter.
Kurt W.
RV9A
FLYING!!!
Old 09-10-2012, 06:36 PM
Thank you, I did not explain it's purpose correctly.
Ron
Old 09-10-2012, 08:22 PM
Paul Tuttle's Avatar
Paul Tuttle Paul Tuttle is offline
Ron,
My friend works for IMP and uses them , he says they work pretty good.
Paul Tuttle
RV 8
C-FPVT
Flying.
Old 09-11-2012, 05:38 AM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
I used one when I pulled my tanks. It worked very good for cutting the paint around the screws.
The only thing is that if paint has filled the head of the screw, you MUST remove enough for the point of the cutter to properly center on the screw. If you don't then the tool might cut off center and paint will be removed in places that you don't want it to be removed. Don't ask me how I know...
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
