Old 09-10-2012, 05:54 AM
rbibb's Avatar
rbibb rbibb is offline
Default Ghost in the Garage
Now I'm not one who has strong belief in ghosts, or other para-normal phenomena. But over the weekend my inclination to discount such stories was, if not erased, at least shaken a bit.
I'm working on the RV-10. At the stage where the front and mid section of the fuselage are bolted together at the spar carry-through in order to drill the bottom skin rivet holes where the bottom skins overlap and will get riveted to the spar carry-though assemblies.
I had completed the procedures and was in the process of unbolting the parts in order to complete the ritual of debarring, dimpling, and ultimately riveting the skin in place.
The scene was at the point of removing the large bolts that tie the two spar carry-through assemblies together. All was well until I encountered a couple of bolts that were a bit stubborn and refused my gentle efforts to remove them. I am working on the starboard side with the fuselage sitting on a table I had built to hold it. I decided to enlist the aid of a bit of mechanical assistance in the form of a small dead-blow hammer for to tap the bolts a bit. Said hammer was located in my roll-away tool box located on the port side of the aircraft so I walked about the front of the table to retrieve the hammer and returned forthwith. Estimated time enroute was on the order of 5 seconds roundtrip.
Upon arrival, hammer in hand, there, on the top of the spar where it extends from the fuselage side where the bolts that provided so much angst pass through I was confronted with one AN-4 bolt, estimated length 1.25", sitting vertically on top of the spar assembly. Not so strange you say to find a random piece of aircraft hardware lurking amidst the organized chaos of a construction project? Well here's the rub. At no point in the efforts to that point had occasion arisen to use an AN-4 bolt in efforts so far. There was not an AN-4 bolt within 15 feet before the stray perched vertically in such a delicate fashion so placed as my supply of such were firmly resting in their storage bins firmly attached to the garage wall awaiting their fate at a later stage of construction.
So I think to myself - how did that get there? I was there not 5 seconds before, had not employed such device, had no such devices within arms reach, and, in its perilous perch, would not have remained in that place for long given the mount of movement employed to shift the fuselage assembly around as it was worked on prior to its discovery.
In fact, quite shaken by the event I retired from working thinking I a) either had help in working on the project I had not solicited nor welcomed, or b) was suffering from some manner of senility offering a warning of steep mental decline.
After a bit I returned to work. Shaken and still not in possession of any reasonable explanation for the phenomena I had just witnessed.
Richard Bibb
RV-4 N144KT
RV-10 - future result of pats scattered throughout the environs.
Old 09-10-2012, 06:17 AM
Talking Our clinic is able to help
Did you hear any voices Richard? Do you remember what day is it?
Old 09-10-2012, 06:23 AM
apkp777's Avatar
apkp777 apkp777 is offline
Sounds like the AN4 bolts the RV9 guys were forgetting to put in the spar that generated the SB. Everyone still kicking at Van's? Could have been a Van's Aircraft ghost that mistook you for a -9 builder?
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 09-10-2012, 06:24 AM
bsacks05's Avatar
bsacks05 bsacks05 is offline
According to Wikipedia, Clifton, Va. was a native American hunting ground and an important source for timber in the Civil War. Helpful spirits lurking around? Seems plausible.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 09-10-2012, 06:57 AM
bkthomps bkthomps is offline
the simplest answer is usually the correct one, you're probably senile
Old 09-10-2012, 07:17 AM
2bolts 2bolts is offline
A close encounter? Did 'time' seem the same on your return?
Roger
A Brit in Texas
RV8 N886LH (Reserved) BuNo 83320
Collecting books/info/tools.
Tail kit arrived! 9/30/2012
Construction started
"The engine's overheating, and so am I! Either we stand down, or blow up! Now which do you want?" Sqn Ldr Canfield.
Old 09-10-2012, 07:30 AM
Paul Tuttle's Avatar
Paul Tuttle Paul Tuttle is offline
Default Don't laugh...
There is a force in my shop that takes over my mind and causes me to make incredibly stupid mistakes. It also moves every tool I have just used and cleverly places it among the clutter so I can't find it.
Paul Tuttle
RV 8
C-FPVT
Flying.
Old 09-10-2012, 07:33 AM
Rupester Rupester is offline
...a visit by the Ghost of RVs Past !?
.... or maybe .... the Ghost of RVs Future ??!!! (Don't tell the wife.)
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 09-10-2012, 07:42 AM
paul330 paul330 is offline
Hah - I was looking for that bolt. Is this wht I can never find anything in my workshop?
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 09-10-2012, 08:28 AM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
I agree and saw this in the movie the 6th Sense
David
EAA 1250 KPTW
Royersford, PA
david@rv12pilot.com
2020 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
