Old 09-09-2012, 07:36 PM
SteveHRV7 SteveHRV7 is offline
Default Elevator Squeak
The plane is back from the paint shop. When I put the tail back on and hooked up the elevator push tube I noticed that there is a "squeak" when the elevator is in the full up position. It is coming from the forward side of the right elevator rubbing on the aft side of the horizontal stabilizer. Both these two surfaces received two coats of paint and two coats of clear coat. This rubbing was not present before paint. There is some resistance that can be felt at the full up position but not enough even to hold the stick full up when you let go. The elevator easily hits the stop. Due to access it would be very difficult to remove the elevator and sand everything down but it could be done if need be - and that is my question. Is this necessary? I am positive that the rub is due to the thickness of the paint and not related to any other structural problem. Fix it? Let it go and see if it stops?
Thanks!!
Steve Houghton
RV7a
Okemos, MI
N807SH
Old 09-09-2012, 07:44 PM
xblueh2o xblueh2o is offline
Flight controls is just one area to not mess around with.
I am far from an expert but if it were mine I would fix it.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 09-09-2012, 07:55 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Try turning both rod ends out a half turn and see if that solves the problem. They still very well might line up OK with the center bearings and control horns.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 09-10-2012, 07:43 AM
Rupester Rupester is offline
If you can see where it's rubbing, maybe a light touch with some sandpaper ... just to reduce the 4 layers of paint/clearcoat?
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 09-10-2012, 07:48 PM
Default Fixed the rub
Decided the best thing to do was pull the elevator. There was some rubbing on the inboard, forward side of the elevator. I drilled out the inboard 4 rivets, squeezed the bend smaller and re-riveted it. Squeak gone! Took four hours but in the end it ws the right thing to do. Thanks for all your replies.
Steve Houghton
RV7a
Okemos, MI
N807SH
