09-09-2012, 01:24 AM
Dual PC680 on RV-7(A) or RV-9(A)
Has anyone installed two (2) PC680 batteries on an RV-7(A) or RV-9(A)? I searched the forums and found some on RV-8(A) but that's all. Would appreciate pictures if you have them.
Thanks in advance.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
09-09-2012, 05:30 AM
There are plenty of RV-10s in this configuration, mine included.
09-09-2012, 07:20 AM
On a 6A ... yes.
Thanks in advance.
On my *unfinished* 6A project, I have what is effectively the AeroElectric Z-14 configuration. The mounting and wiring of components on firewall and feed to dual busses is done.
Contact me via jclarkmail -<<at>>- gmail.com for details.
James
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
09-09-2012, 08:29 AM
I'm not around my pics but yes, I have 2 PC680s on my 7A. I have 2 separate master switches and except for those switches they are electrically isolated from each other. They are mounted on the upper firewall behind #3 cylinder and I attached a charging pig tail to each one separately so I can reach them through the oil door. I made my own battery tray with aluminum angle hold down "straps" all tied to the firwall with additional angle bracing on the cockpit side to help it hold up the extra weight to 6gs. They are one in front of the other in the tray. I'll look for pics whenI get home.
All Best
Jeremy Constant
RV7A "Stella Luna" ECI IO-360 WW200RV Pmags 360hrs
VAF 2019 paid plus some for those who can't
09-09-2012, 08:48 AM
Yes, I have...
...it was back in 2003 with the Subby engine.
Uploaded with ImageShack.us
The charging of 2 batteries with 1 alternator was controlled by EXPBUS with the dual battery option. It worked well. It was mounted on a slightly raised platform with the fuel lines running under it. Final install included a fiber glass cover over the 2 batteries.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
09-09-2012, 08:50 AM
Below is a photo of my right battery install and the battery solenoids (2) and the starter solenoid. The left battery is in the mirror location on the left side. Vans bat. boxes located vertically so i can just barely get the batteries out of the box. My cg is pretty far fwd. Suggest u consider a prop lighter than my hartzell ba prop, or go with li-fe batteries.
https://lh6.googleusercontent.com/-n...3559.jpg?gl=US
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
09-09-2012, 10:05 AM
I have two PC680s on my firewall too. The front of the battery box on the left side is cut open and hinged on both side to make battery replacement easier (not my original idea). I have fixed pitch prop so it is lighter. I have no WB issues. I can go from solo, minimum fuel, no load to gross without getting out of the CG limits.
Wiring diagram
Installation picture
Battery box with hinges
Looking from above, battery will not come out from top.
Aux solenoid installed below master solenoid.
Ted Chang, VAF #681
2018 Due paid
09-09-2012, 11:35 AM
Thanks all for the pictures. The mirror image of the left battery to the Van's right battery installation is an attractive option and would be my first choice. The hinged front battery box also makes sense. I guess I should have mentioned I will have a constant speed prop, and my concern with the mirror image left battery installation is that it will interfere with the prop controller cable. I'm still assembling the forward fuselage, so I don't have the engine, engine mount, prop cable or PC680 box to decide on a location, but I'm trying to plan well in advance. Can the prop controller cable and cable mount be clocked or installed so that it misses the left battery box?
Terry Edwards
RV-9A (Fuselage)
09-09-2012, 12:31 PM
Counting rivet holes on the drawing, looks like it will work. You may have to move the control cable holes slightly higher. Use your main battery hardware as templet and try it out on the left side before you drill the holes. Battery box has to open from front.
Ted Chang, VAF #681
2018 Due paid
