Old 09-08-2012, 07:27 AM
wadem wadem is offline
Default determining compression ratio- NEW GUY
Hi guys,pulled the trigger and bought a 4! very excited and have a million questions....this is what I'm trying to figure out today!
Is it possible to determine what compression pistons are in an engine,i.e.,formula,compression check etc? engine is a O-320 E2D, which was only 150 hp (low compression) but seems to have a lot more.
Previous owner (who was not the rebuilder) has supplied a bunch of receipts of engine parts and the piston numbers are 73851. This makes no sense to me as all the research i have done says these are O-235 pistons (low compression)
would these work in an O-320? I also have piston ring number and other part numbers if it may help.
I want the ability to run regular octane mo-gas, thats why the enquiry, if i can't its no big deal, just trying to find out.
This plane is great! runs awesome. Serial number is 1537, originally built by Ralph Dye, and then I believe Dave Lathum of Washington state. If anyone has any track history or info on this plane please pass it along!
From what I can tell most parts were ordered from Superior Air Parts Inc. From there it looks like Ralph had the engine built by Pointer Aviation. (Good place??)
Any help here guys would be greatly appreciated, again awesome site and am happy to be aboard!
Old 09-09-2012, 05:55 AM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
Default Read all of the logbooks
There should be a complete history of the aircraft in the airframe, engine and prop logbooks. There should also be compression readings of all of the cylinders in the last conditional inspection report. Welcome to the club. I flew a "6" for 8 years with a 150 HP engine and loved it. I'm sure you will learn a lot and have many enjoyable hours.
Old 09-09-2012, 06:48 AM
FlyingArcher's Avatar
FlyingArcher FlyingArcher is offline
Default Not in O-320 Parts Catalog
Hello Wade,
Looked up in my O-320 PC and no reference to your piston p/n in here.
Here is the cross-reference for cylinders and pistons so you might find some help with it.
Good luck
Daniel Mouly
VAF #778 - [2013 payment done]
RV-9A Emp. & Wings 95%, Fuse 70%
Austin Healey 3000 MKIII fully restored
LFCD (Andernos Les Bains), France
Construction Log comments in French (not really up to date, sorry)
Old 09-09-2012, 07:23 AM
TomVal's Avatar
TomVal TomVal is offline
Originally Posted by wadem View Post
...From what I can tell most parts were ordered from Superior Air Parts Inc. From there it looks like Ralph had the engine built by Pointer Aviation. (Good place??)...
Since you have the name of the engine shop that built your engine, they could best answer your questions. What would help them in locating your engine build sheet is giving them the work order number on your engine overhaul invoice.
Regards,
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
