Old 09-07-2012, 11:02 AM
Pmerems's Avatar
Pmerems Pmerems is offline
Default New Kindle Fire HD
For those who haven't heard yet Amazon has introduced several new Kindle fire products this week. The new Kindle Fire HD has a new screen construction that might be an improvement for those using the tablet in the RV cockpits.
Reduced Screen Glare
Most tablet displays are made up of two pieces of glass - an LCD on the bottom and a touch sensor on the top, separated by an air gap. With an air gap, light reflects off of every surface as it passes through from the front, creating multiple distracting reflections that reduce display contrast. Kindle Fire HD solves this air gap problem by laminating the touch sensor and the LCD together into a single layer of glass, creating a display that's easy to view, even in overhead light.
Richer Colors at Wider Angles
Like many tablets, Kindle Fire HD uses In-Plane Switching (IPS) to improve color reproduction. But displays that only use IPS still appear washed out at various angles, such as laid sideways when reading in bed, laid flat on a table, or held between you and a friend when sharing a movie. Kindle Fire HD addresses this issue by applying an advanced polarizing filter directly to the LCD panel. This results in a display that shows the same deep contrast and rich, detailed color when viewed at any angle.
If you are going to take the plunge and purchase one of these HD's please post your "in cockpit use" feedback to the forum as soon a possible.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
