Old 09-04-2012, 11:30 AM
Don Jones's Avatar
Don Jones Don Jones is offline
Default Build a paint booth----check
Spent the long weekend building a paint booth to paint the project. I framed it up with lumber so it was more robust since as soon as the plane is painted the wife has informed me I was painting her little work car. Still need to put the plastic on the roof and finish the ventilation system and lighting, but should work well. Paint and off to the airport!
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 09-04-2012, 12:42 PM
cytoxin's Avatar
cytoxin cytoxin is offline
looks great.....good luck
William Weesner/ still kicking.
Old 09-04-2012, 12:57 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Paint her car first, get some practice in before you do the plane
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-04-2012, 01:02 PM
Don Jones's Avatar
Not happening--- no place to store the plane while the car is in the booth and I want that airplane done and at the airport!
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 09-04-2012, 08:14 PM
Fearless's Avatar
Fearless Fearless is offline
Looks good. Don what are the dimensions you used for your booth? I'm about ready to start painting components as well.
Mike
RV-9A Based K6I2
Flying - out of Phase 1
Building RV-12 with brother
Old 09-04-2012, 08:17 PM
N9331v's Avatar
N9331v N9331v is offline
When you install your ventilation system can you post pictures
Ed Martin
Bluskydtl
RV7
DKB
Donations 1/19 & 6/19
Old 09-04-2012, 08:22 PM
Captain_John's Avatar
Don, That is sweet!
My plans are similar to yours. I don't want to remove the plane from service to paint it.
This advice came from Vlad. He is wishing that he painted prior to first flight for that very reason!
Looks great!
CJ
RV-7 Flying - 1,400 Hours
Old 09-04-2012, 09:36 PM
Don Jones's Avatar
The booth is 10 x 20 and has plenty of room. Should work nice!
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 09-04-2012, 09:39 PM
Don Jones's Avatar
Sure, you can see the exhaust filters mounted in the door. I am blowing air into the booth and filtering the exhaust to keep the overspray off of stuff I don't want painted When I get the fan system installed I will post pics.
Don Jones
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 09-04-2012, 10:59 PM
Rockyjs Rockyjs is offline
Default Another Paint Booth
I used a PVC booth last year on another project. I wanted something a bit more robust for polyurethane. I bought a 10' x 20' portable garage that uses 1" steel tubing that bolts together ($212). After I've finished painting the garage will house a small pickup truck. I covered this with 3 mil plastic instead of the supplied canvas material. The plastic is clamped on using 2" lengths of 1 1/4" PVC that have a section removed allowing them to open and go over the steel pipes. I then constructed a door frame with 6- 24"x20" filters for the intake and collector box using 4- 24" x 20" filters. Northern tools has a blower motor which I use in a suction mode at the end of a 12" diameter 20' long flexible hose. I open a side door at the hangar and place the motor out the side door. It exchanges the air every 1 1/2 minutes and works great. The only thing I would change is to make it bigger. I believe a 12' by 24' would be ideal. Lighting is supplied with 6 dual bulb 4`flourescent lights attached along the top rails using 1" electrical conduit plastic clamps.
Rocky McKiernan
Navarre, FL
N767JM RV-7 Flying
N1011D (res) RV-10 Building
