The only thing that will cause both the alt and encoder to have an error is a bockage in the static system somewhere before they 'T' off to the respective units. I would look for a slug of water at a low point somewhere.
The encoder is referenced to 29.92, setting the alt to 29.92 is the only time the altimeter and encoder will match.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
