  #11
Old 09-03-2012, 06:23 AM
JakeLewis22 JakeLewis22 is offline
Default Thanks!
Thank you for the congratulations, compliments and well wishes. As I said before, the VAF community can take some of the credit. There were countless times I came to the search function on this site unsure of how to proceed and discovered that many builders before me had encountered the same exact problem. That's the advantage of having nearly 8,000 builders ahead of you.
Since I'm passing out thank you's, I'd like to publicly thank my son Nick. About 4 years ago we had plans to go out to dinner and I had about 30 minutes to kill so I picked up the air drill and started match drilling a wing skin. When he arrived he made the mistake of saying "I'm not that hungry yet, do you need any help?" He ended up drilling and deburring about half the holes on the airplane and operating the rivet gun on almost every "shot" rivet. Thanks Nick!
Originally Posted by ColoCardinal View Post
SWEET!
I may steal that paint scheme; love it!
Feel free to steal it, I stole it from a red & white RV-7.
For those of you thinking about painting your own airplane:
Painting was without a doubt the most physically demanding step in the process. I didn't realize how physically demanding it was until the morning after the first day of painting when I could barely get out of bed. I also underestimated how much time and work goes into masking off a multicolor paint scheme. BUT, it was also one of the most rewarding parts of the build.
Jake Lewis
RV7 - N223J
"First Flight September 1, 2012"
www.photobucket.com/jakelewis22[/size]
Old 09-03-2012, 07:57 AM
KCBerner's Avatar
KCBerner KCBerner is offline
SWEET!
Ditto. Adding it to my bookmarks folder of "Paint Jobs I Like". Beautiful.
Congrats
K.C.
RV-14A #140026
Wings 70%. Emp 70%
Happy to be a 2020 =VAF= contributor
Old 09-03-2012, 12:13 PM
BSwayze's Avatar
BSwayze BSwayze is offline
BEAUTIFUL job, Jake! I'm contemplating painting mine, too. I'd really like to have it done before it flies. Do you have any notes or build log online anywhere? More pics, especially of the painting process you went through? What kind of paint did you use? Base coat, clear coat?
Have fun flying, you've done such a beautiful job!
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
Old 09-03-2012, 12:30 PM
GAHco's Avatar
GAHco GAHco is offline
Default Awesome ! ! !
All those pictures on your picture site that you shared with me, came together very nicely!
Congratulations and have FUN
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 09-03-2012, 07:21 PM
panhandler1956's Avatar
Default Congrats!
Great job! Congratulations and good luck with phase 1. Sure is a pretty airplane!
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 09-03-2012, 10:58 PM
Hi Bruce,
I agree, I wanted the airplane to be finished before it flew.
I started out posting pictures to photobucket so my brother could keep track of my progress and it turned into a quasi builder log. Click on the link under my signature below. The pictures are organized by date and the painting pictures run between 2012/05/05 and 2012/07/18. If you click on the thumbnail pics they'll enlarge and you'll be able to see captions under most of the pictures.
An auto painter friend recommended I use BASF's RM Diamont base coat, clear coat. He also offered the use of a spray booth at an auto body shop on the weekends. I contacted BASF's tech line and they confirmed it would be good for an aluminum airplane and recommended the best primmer to use (EP569 Chromate Free Epoxy Primer). They also emailed me spec sheets for using Diamont on aluminum aircraft.
My friend coached me through the first few parts and then I was on my own. There were no surprises with the paint but as I said before, I underestimated the time needed for masking.
It worked out best to apply the primer Saturday morning and spray the white Saturday afternoon. I'd leave the white parts in the booth to dry overnight and start masking the 3 color pattern around 8 am on Sunday morning. The masking would take all morning and I usually wasn't spraying the gray until early afternoon. When the gray was dry (30-45 min) I'd mask it off and spray the black. Then mask off the black and spray the blue. After another 30 minutes for the blue to dry all the masking came off and I'd shoot the clear. The base colors are flat so they dry pretty quick but I found it was best to let the clear dry overnight before handling or I'd end up with finger prints. Once again I'd leave the parts in the booth overnight and pick them up Monday morning on my way to work, before the body shop opened.
After six weekends of that I was wiped out.
Jake Lewis
RV7 - N223J
