Old 09-01-2012, 10:16 PM
Michael Burbidge Michael Burbidge is offline
Default Carburator nut and fitting question...
One nut on the carburator is impossible to get to with the cable bracket and fuel inlet fitting blocking access to the bolt. I assume if I remove the fitting that I will be able to get the nut on. It still looks like it will be very difficult to get a wrench on. Is there a special wrench for that nut? Can I remove the fitting. I don't recognize the kind of fitting on the carburator. A normal pipe fitting screws into that fitting. It looks like there is a screen behind the fitting.
Here's the picture of the bolt I'm talking about.
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Last edited by Michael Burbidge : 09-01-2012 at 10:17 PM. Reason: Forgot to include the photo.
Old 09-02-2012, 12:08 AM
Default Got it...
I wish there was a way to delete a post. I was too quick to ask for help.
I set the nut and washers on my little finger and was able to hold them against the bolt while I twisted the nut with the index finger of my other hand. Once the nut was on it protruded down past the bracket far enough that I could get a box end wrench on it and twist it one flat at a time.
I promise not to ask anymore questions for at least a day!
Michael
Michael Burbidge
Sammamish, WA
RV-14A Empennage
Old 09-02-2012, 07:20 AM
Mel's Avatar
Mel Mel is offline
You should have an "edit" button. When you click on it, you should get a "Delete" button.
A moderator can delete it for you. Sorry, I've been stripped of those privileges.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
