Old 09-01-2012, 07:21 PM
pa38112 pa38112 is offline
Default How do I update a Garman 296?
I have a Geaman 296 that has not had the database updated since 2004. My computer does not have a port that will accept the plug that came with the unit, so I bought an adaptor to a USB. The computer says that it does not see the device. I am thinking that just because the adaptor fits it does not mean that it is compatable- Any idea how to get it updated ?
Old 09-01-2012, 08:18 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
I have updated some x96...not sure which. My recollection is that the data cable connects to the GPS unit (cannot remember where) then to a USB port.
Find a friend with a computer that has a suitable connector....or try a local library.
Old 09-01-2012, 08:28 PM
bpattonsoa bpattonsoa is offline
Are you sure that Garmin still supports the 296?? I still have a 195, (not 196) in my -6 and went to update last month. They no longer support that device. Sort of ticks me off, it is not that old and works just fine. How much effort is it to run their more modern databases thru a converter to provide for that "old" device?
Will be a consideration when I am putting together the panel for the -10. Almost certain the Garmin will not be there.
Bruce Patton
Rans S-20 Raven 796S flying since 2019 (slowly)
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S flying since 2014, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum. 1624 lbs, FLYING after a 21.5 month build.
Old 09-01-2012, 08:43 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Hmm, it appears there is some less than correct information in this thread. Navigation and obstacle databases for the GPSmap 196 are certainly still available, as are database updates for all the following Garmin portable aviation units:
  • aera 795/796
  • aera 500 Series
  • GPSMAP 695/696
  • GPSMAP 495/496
  • GPSMAP 396
  • GPSMAP 296
  • GPSMAP 295
  • GPSMAP 196
  • GPSMAP 195
  • GPSCOM 190
  • GPSMAP 96/96C
  • GPS III Pilot
  • GPS 92
  • GPS 89
Note that new databases are still available for some units that have been discontinued for many years! By the way, the above is straight from the price list that's linked to on the front page of fly.garmin.com, which is where you go to update your databases.
- Matt
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 09-01-2012, 09:00 PM
Wayne Gillispie Wayne Gillispie is offline
I downloaded an "updater" program from above Garmin website and update my 496 occasionally with no problems.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 09-03-2012, 05:59 PM
bkilby's Avatar
bkilby bkilby is offline
Default "fly garmin" site
I just updated my 296 tonight... You also have to go to the "fly" garmin site in order to update your aviation gps. Go to the bottom of the garmin site, and look for the link that says "flygarmin". This is where you navigate to in order to buy navdata updates. I have a garmin cable that is USB on one side and the other side looks similar to a micro usb connection that most smartphones use nowadays. There is small rubber plug on the back of the gps that you pull out and accepts the micro usb looking connector.
Brian Kilby
flying RV-6A, previously flying RV-9A
based at KCTJ, Carrollton, GA
Old 09-03-2012, 06:34 PM
rjtjrt rjtjrt is offline
G3X Matt
The x96 series are classics in the most positive use of the term.
I am sure they will be used for many years to come, and applaud Garmin for continuing to support them with database updates, and hope this will continue.
Solid long term support separates honourable customer oriented companies (like Garmin) from the rest, and guarantees loyalty from it's customers.
John
Old 09-03-2012, 06:35 PM
AltonD's Avatar
AltonD AltonD is offline
The adapter cable is more than just a cable. There should be some electronics buried in the USB end. You should have gotten a disk with the cable to load some software.
I updated a 295 just last week. Worked great.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 09-03-2012, 07:12 PM
cbo111's Avatar
cbo111 cbo111 is offline
Life is too short to use a crappy old GPS
Chuck O
TSP
RV-7A (sold)
Old 09-03-2012, 07:15 PM
AltonD's Avatar
It wasn't mine. I have a 430W and a 696. I am update poor.
Alton DeWeese
N4IDH
Construction Log
?Mark Twain
