Old 08-31-2012, 06:36 PM
crabandy crabandy is offline
Default Wiring around bell crank
I ran my strobe and wingtip light wires through the tooling hole in the rib underneath the pitot line and underneath the bell crank next to to spar. Do I need to secure the wires under the bellcrank and if so what is the best method. Also should I tie wrap the wires together between the ribs, I did not use conduit only the snap bushings.
Thanks!
Old 09-01-2012, 04:22 AM
jarvis jarvis is offline
If you look at Roee Kalinsky's build site under "pitot-static system", you'll find a pix of how he did it--which is bullet-proof in my opinion. This applies to all his work BTW-a real craftsman. I believe it's Kalinskyconsulting dot com or you can do a search on VAF.
I hope I've spelled his name correctly
Jarvis
Purchased flying RV-7A
RV-7A emp finished, wings next.
Old 09-01-2012, 11:34 AM
Rupester Rupester is offline
I used several tie-wraps thru that bay, tied to those those nifty tie-wrap pads that I RTVed onto the back of the spar. Ended up very tight and solid.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
