Old 08-31-2012, 03:39 PM
Michael Burbidge Michael Burbidge is offline
Default Anti-sieze vs. teflon paste...
I'm a little confused as to when I should use anti-sieze vs. teflon paste when attaching fittings to the engine. For example, I'm at the point of installing the aluminum fitting that comes with the Vans manifold pressure install kit in the pressure port of the #3 cylinder. Would I use teflon paste on that fitting, or some sort of anti-sieze compound?
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 08-31-2012, 03:54 PM
bird's Avatar
bird bird is offline
I am sure someone with much more exp. than me will charm in soon. As for me, I would use neither, instead use permatex #2.
bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 08-31-2012, 04:57 PM
aerhed aerhed is offline
I generally think of anti-seize as a high temp lube. Ex. nuts, slip joints, etc. That fitting is more low temp (permatex form-a-gasket).
Actual repeat offender.
Old 08-31-2012, 05:57 PM
rocketbob's Avatar
NPT tapered thread, use pipe dope of your choice.
Straight threads into the case (spark plugs) use anti-seize.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 09-01-2012, 05:51 AM
Captain_John's Avatar
Plus one on the Permatex #2 for any liquid retaining NPT fittting!
The stuff is DESIGNED to seal threads and the like. It stays pliable and cleans up with Coleman fluid.
The Anti-Seize compound is quite different. It IS NOT designed to seal and contains zinc to ward of (or actually become a sacrificial anode) corrosion and keep parts from welding themselves together via the corrosion battery.
Places for Anti-Seize are CHT sensors, spark plugs and the like.
Does this help?
CJ
The experiment works!
Old 09-01-2012, 12:04 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Another fan of the Permatex brown goo (#2 or #3) for thread sealant on these fittings. It gets the job done perfectly.
Neal Howard
Airplaneless once again...
