Old 08-31-2012, 03:28 PM
crabandy crabandy is offline
Default local ground on adel clamp bolt?
For a local ground on the wingtip for nav/ldg lights I was thinking of using an adel clamp to secure the wires to the outboard rib before the service loop. I was thinking of using a longer bolt for the adel clamp and securing the clamp with a regular nut and using the longer bolt as my local ground point as well using the washers/nut combos shown in the 43.13 for a standard bolt through local ground. Is this acceptable?
Thanks!
Old 08-31-2012, 04:12 PM
N941WR's Avatar
N941WR N941WR is offline
I just added an extra platenut on the last rib and used that.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-31-2012, 04:46 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Is this acceptable?
Thanks!
Yes.....(extra words to allow posting)
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
