Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
  #31
Old 10-13-2013, 12:32 PM
crabandy crabandy is online now
Just the full dual ignition, I've only glanced at the fuel injection. My airframe was setup for the carb and my carb had a yellow tag so I stuck with that. It's on the back burner of possible future upgrades, fly first then radios and paint.
RV 7 400 hours and counting
19 donation done
Old 10-13-2013, 04:28 PM
rcpaisley's Avatar
rcpaisley rcpaisley is offline
Default Dual ECU fuel injection setup
For more info on how the Dual ECU version of our fuel injection works, check out the Dual ECU Addendum at the end of the installation manual. It is linked on our Customer Area page.
Basically, both ECUs have their own redundant critical sensors, including a dual crank trigger, dual IAT and dual MAP sensors. One ECU runs the top plugs, one ECU runs the bottom plugs. A panel mounted "ECU select" switch transfers injector control from one ECU to the other. It is a very simple and reliable scheme.
Robert
EFII www.flyefii.com
Protek Performance
Old 10-14-2013, 07:17 AM
JurcaSperocco's Avatar
JurcaSperocco JurcaSperocco is offline
I'm willing to substitute my D-3000 dual-mag with a Single Mag plus an Electronic Ignition System (brand not yet defined).
Does somebody know what's the best replacement to a single 6 cylinder magneto fitting my AEIO-540-L1B5D engine?
Thanks in advance.
Best regards,
Patrick
Paris, France
www.marcel-jurca.com
www.rsafrance.com
Not building a RV, nobody's perfect
2012 to 2019 dues... gladly paid!
Old 06-03-2014, 04:36 AM
FYI, I've chosen Robert's EFII EIGN-6-2R Dual ECU, Dual ignition system for 6 cyl Lycoming, also adding the Bus Manager + VP-X.
Best regards,
Patrick
Paris, France
www.rsafrance.com
Old 06-03-2014, 11:29 AM
walkman's Avatar
walkman walkman is offline
I just bought another ignition for my new -8, and a new fuel pump. Man that pump is a work of art.
Robert has been extremely helpful in answering all my questions and dealing with my constant pestering.
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 09-08-2015, 05:26 PM
E-17B E-17B is offline
Default Reliability
While this is an old thread, I'm curious about the D-3000 mag. I've reviewed Mx instructions on it, it looks rather complicated and problematic, and I would guess expensive to overhaul. However, I find nothing on the site regarding failures of the D-3000. Yes, I understand efficiencies possible with electronic ignition, etc. The single point of failure argument I presume concerns the single drive, but my old radial had a similar arrangement and worked well. So, honestly, is there a safety issue with this magneto? Thanks.
Bill McClure
RV-8
Cape Cod, MA
