Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #11
Old 08-29-2012, 07:40 PM
jetdriven jetdriven is offline
That looks a lot like a Mooney M20J spinner. Is it?
Byron
1977 Mooney 201
Houston, TX
Old 08-30-2012, 04:23 AM
pierre smith's Avatar
Default Nope.
Originally Posted by izzybear View Post
Yep, looks good and fast! No doubt!
Actually, the big gaps between the spinner and the prop creates a lot of drag, as do the lips around them...sorry, but it's true.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 08-30-2012, 02:34 PM
smokyray's Avatar
smokyray smokyray is offline
Default No doubt...
Best, Pierre
Amen brother, proven fact.
V/R
Smokey
PS: Appears to be a Cessna 310 Spinner, lots of em on HR2's....
Old 08-30-2012, 07:11 PM
Captain_John's Avatar
Thanks guys.
It is a c-3532 spinner with a 2294 bulkhead. Yes, it seems to have been from a Mooney M-20. I got it off ebay and am going to give it a whirl, literally I suppose!
As far as getting it lined up, yes the diameter is an inch larger than Vans so it does come a bit proud of the cowl inlets, perhaps 1/8" on each side?
Pierre and Smoky ray are right, it will be trailing behind the pack about .0437599 knots slower, but I don't care.
Thanks to Les from Hartzell for hooking me up with all the technical data I needed.
This is why we are building experimental planes, isn't it? So we can customize them the way we want to?
CJ
The experiment works!
Old 08-30-2012, 07:15 PM
Originally Posted by Michael White View Post
CJ,
I think you're gonna have a tough time getting the cowl to match...
Moose, this is why i posted the thread. I want input from my fellow builders to make this work. Aside from the diameter being larger and having to contour the lower cowling to match it, what other issues do you think I might need to address?
CJ
Old 08-31-2012, 08:47 AM
Michael White's Avatar
CJ
CJ,
I was talking about the chrome...
You already know you'll have to build up the cowl (not just the lower cowl...top & sides too) behind the spinner to get a good match...why not consider installing a set of Sam James inlet rings too? That way you can build up the sides as needed without worrying about closing off too much of the rectangular inlets.
Moose
VAF #136
Old 08-31-2012, 10:36 AM
HA! OK, I gotcha!
I was just thinking about how sweet a totally tin and polished cowling would look! Can you imagine the work involved?!?
To be perfectly honest with you, I am highly allergic (for real) to curing epoxy resin. I can't even get near the stuff! I am going to get this all fitted and leave the details to others. I simply cannot do it.
I know some people who could probably do it for me and have it look good. Perhaps, no probably a better job than I could do myself!
Lots more to do!!!
CJ
Old 08-31-2012, 11:03 AM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Gives new meaning to "keeping the pointy end forward".
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 08-31-2012, 12:38 PM
smokyray's Avatar
Default Weight a minute...
This is why we are building experimental planes, isn't it? So we can customize them the way we want to? CJ
Absolutely John. I will add: to fly economically and Experiment. Most anything you can bolt on an RV (or Rocket) has already been tried and tested, chrome Mooney spinners notwithstanding...
V/R
Smokey
See anything familiar?
Old 08-31-2012, 03:24 PM
Talking
From the prop flange forward, thats the finest airplane ever made!
Byron
1977 Mooney 201
Houston, TX
