Old 08-28-2012, 07:28 PM
UnPossible's Avatar
UnPossible UnPossible is offline
Default Gear Leg Fairing Alighnment and Trim Tabs
Hey - I am finally getting around to fitting my gear leg fairings.
With the wheel pants on, the ball was centered pretty much all the time.
Now with the gear leg fairings installed, I am seeing a 1/8 to 1/4 of a ball defection to the right in cruise.
When I slow way down <100 kts), I think I am seeing a very small deflection to the opposite direction (left)
I'm curious as to the best way to fix this. My lower transition fairings are only pop-riveted on at this time. ( I wanted to be able to reposition them if there was a severe alighment issue before I glassed them in).
Should I drill out the lower tranistion fairings and try to realign one or both of the gear leg fairings, or should I just slap a small trim tab on the rudder and be done with it?
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
Old 08-28-2012, 07:38 PM
hydroguy2's Avatar
2 wrongs don't make a right. Get the fairings aligned...then make a tab if needed.
Old 08-29-2012, 12:53 PM
UnPossible's Avatar
OK - will take another shot at getting them totally aligned before I resort to a trim tab.
What I am struggling with, is how to get my alignment spot on with a less than level hanger floor.
I was able to level the scrap door I was using as a reference back by the tail side to side, but not sure how best to level it front to back with the gear legs when the distance is 10'+.
Is there an easy way to do this that I am not coming up with?
Jason
Jason Tremble
Paid for 2020
Old 08-29-2012, 01:05 PM
hydroguy2's Avatar
To properly do the gearlegs, You need the plane in a flying attitude.
So jack it up off the ground with wing jacks. Put a level across the longerons for the side to side. AND a level on the side rail. Now use the dual string method to center the gear leg. check this thread.
Old 08-29-2012, 04:44 PM
Loman Loman is offline
Default A Water Level will do it.
Use a length of hose filled with water and clear tubes at each end (or just a long length of clear plastic tubing). That way, you can find a level on your door that matches the level of the string location on the leading edge of your gear leg fairing, regardless of any hills and valleys between the two.
There are lots of 'how to' water level videos on Youtube if you need them.
Loman O'Byrne
RV9 TU. O-320-E2D. Engine hung, working on FWF, Arklow, Ireland
=VAF= dues paid through Dec 2020
