Old 08-28-2012, 02:42 PM
Michael Burbidge Michael Burbidge is offline
Default Wiring between main and starter contactor...
I'm using a short length of battery type cable made by B&C to connect my main contactor to the starter contactor. Both contactors are from B&C. The orientation of the terminal bolts on the contactors does not make for using copper bar easily.
I've enclosed a picture. My question is, do you the think the radius of the bend will put too much stress on this wire? If so, what would you suggest?
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 08-28-2012, 06:22 PM
mannanj's Avatar
mannanj mannanj is offline
Default Cable
Looks ok to me from here. If you're worried about it, make a new one with welding cable. It is super flexible and should make that radius easily.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 08-28-2012, 07:24 PM
Frank Smidler Frank Smidler is offline
Default Bend it
You can shorten the wire and bend the terminal connection over 90 degrees to make a neater installation. That being said, it looks OK as it is as long as it will not rub against the battery box.
Frank Smidler
N96FS, RV-6
Flying 1/11/09
1085 hr
2WI6 Stoughton, WI
Formally of Lafayette, IN
Old 08-28-2012, 07:59 PM
Captain_John's Avatar
...or do it like i did with a twist in the copper bar.
. CJ
The experiment works!
Old 08-28-2012, 08:00 PM
TX7A TX7A is offline
You probably knew this, but when you crimp the terminals on, make sure they are "clocked" so you don't have to twist the cable when you put the ends on the studs. Don't want to introduce any stress.
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 11-11-2012, 07:30 AM
idleup idleup is offline
CJ,
Where did you get that copper bar you used to interconnect the contactors and what size/thickness is it? Also, how did you do the black on there, it looks like rubber. Thanks
Matt
. CJ
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 11-11-2012, 07:42 AM
UnPossible's Avatar
UnPossible UnPossible is offline
Vans sells copper bus bars. http://vansaircraft.com/cgi-bin/stor...oduct=buss-bar
To me it looks like the black is just heat shrink tubing.
Hope this helps,
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
Old 11-11-2012, 07:44 AM
Mel's Avatar
Mel Mel is offline
Originally Posted by idleup View Post
CJ,
Matt
Looks like heat-shrink tubing to me.
p.s. Obviously Jason types faster than I do. My recent eye surgery has slowed my keyboard!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-11-2012, 08:32 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Hope this helps,
Jason
If you want to equal #2 gauge wire, you should use two strips of Vans bus bar in parallel.
One strip is only about 55% the copper cross-section area of a #2 wire.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-11-2012, 10:13 AM
DanH's Avatar
DanH DanH is offline
No. The minimum radius for a wire is roughly the same as the minimum bend radius for sheet or bar material with thickness equal to the individual wire strand diameter. Put another way, the concern is cracking of the individual strands, just like cracking an aluminum sheet part by using a bend radius that is too small.
You're not anywhere near the plastic region for those wire strands.
Concern about "preload stress" is baseless. Consider your torque-to-length Lycoming connecting rod bolts, or the stress on your landing gear right now, sitting quietly in the hangar.
Dan Horton
RV-8 SS
Barrett IO-390
