  #31
Old 10-16-2012, 07:27 AM
BillL BillL is offline
Default Thanks!
I have been fondling that red cube for a couple of days trying to figure out where it will go and thinking about the NPT seal. Information in this thread has undoubtedly saved me hours of headaches.
It is sad that the threads on such a beautifully made part are not more precise. I agree with Tom, a good straight thread and o-ring seal would be more fitting of such a part.
Happily I passed on the EzTurn and decided for my tried and true Permatex Aviation #3. (also confirmed after some research on VAF)
My donation to VAF saves me lots of time! Thanks VAF!
Bill
RV-7
Lord Kelvin:
Old 10-16-2012, 01:25 PM
Rupester Rupester is offline
Default I heard from 9A pal ...
...that the EII people have a "passive recall" (their terminology) on certain serial #s on the red cube. They were non-specific about the basis for said passive recall. I'm willing to bet it's a batch of red cubes with defective threads. The passive recall essentially means they remain passive, while we chase leaks. ( Sorry about the sarcasm there, but I'm hugely irritated by the leakage on that device; it's cost me 6 to 8 hrs flying time) If you call them and you have the right serial #, they will apparently replace your red cube.
Additional info ... I ended up installing the outlet fitting a THIRD time with a hardening thread sealant. That finally cured the incessant leakage. The sealant directions said to wait 48 hrs before subjecting the joint to any pressure ... which I did.
Thank heavens 100LL has blue dye in it. Without the traces of blue on the white engine mount and white cowl, I never would have found the source of the problem.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 04-04-2013, 10:37 AM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Interesting about the "passive recall". If there's a problem, they should really be proactive about alerting people, since it could be dangerous.
I fixed the leak at the "in" side of the red cube back in October with some Permatex #2, and it's still holding up. I'd planned on fixing the "out" side at annual, which is now, and sure enough it's already leaking. Just did the same Permatex fix on that side, so hopefully I'm done messing with this.
Moral of the story: look for leaks with the red cube, and even though it shouldn't be necessary with a tapered fitting, use a good sealant.
-Rob
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 04-04-2013, 12:17 PM
pierre smith's Avatar
You guys flying RV-10's need to be super vigilant about leaks in the tunnel area!
Some of you may not remember Todd Sweezey's explosion in the cockpit of his -10 a few years ago. It blew out the windows and the left tank OFF the airplane, which subsequently was destroyed by fire.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 04-04-2013, 02:36 PM
Was NOT a pretty sight. Very glad Todd and daughter recovered.
Tom
Ridgeland, SC
Old 04-04-2013, 04:11 PM
bird's Avatar
bird bird is offline
Two thumbs up for permatex #2
It is a true and proven sealant
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 04-04-2013, 06:06 PM
N427EF N427EF is offline
Default Fuel Fume Detector
That Fuel Leak I had on my red cube had me concerned enough to
add one of these Fuel Fume Detectors. I have had no leaks or fuel smells
since gooping up both fitting threads with Pro Seal.
http://www.westmarine.com/webapp/wcs...FSHZQgodIFQAuA
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 04-04-2013, 06:54 PM
Skyflyer Skyflyer is offline
Default Google NPT vs. NPTF
Several posts have ask if tapered NPT threads should seal without a sealant. The answer is not necessarily, as a bit of googling will show. NPT threads require the use of a sealant while NPTF do not. Fuel Lube is not a sealant but it might be a satisfactory lubricant with NPTF threads. With NPT threads, which we usually encounter, I always use a PTFE pipe dope/sealant and to date have never had a leak.
Chuck McCluggage
Sugar Land, TX
RV-8 IO-375 WW 200RV
Flying
Old 07-10-2013, 02:02 PM
RV10Rob's Avatar
Another update: it started leaking again at the end of my big trip (though I wasn?t able to find it until I was home). I don?t know whether I didn?t get the threads clean enough when I reinstalled the fittings with Permatex, but decided given the risk to safety and time/effort to keep messing around with this, I?d just start over. One new fuel sender and two new fittings later, hopefully I?m done.
-Rob
Rob Kochman
Paine Field (KPAE)
EAA Chapter 1440
Old 07-10-2013, 02:09 PM
rocketbob's Avatar
The threads on the red cubes are not deep enough. I have a 1/4" NPT tap I use on them which will correct the threads. I have a set of taps for this purpose, ground down NPT taps so they are bottoming taps.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
