Old 08-26-2012, 11:03 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
Default Fabrication Help Needed
I am needing to add some air inlets to my cowling, and would like to make one on each side, identical to each other.
I am up against the problem of how to make them both the same shape, I am not THAT artistic, and don't want them to look like they were made by different people. How do I make a mold that allows them to be identical? The scoops will be located on either side of the large mouth shown in the cowling, and be shaped something like the second photo.
[IMG]
[IMG]
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 08-26-2012, 11:34 AM
If you were able to give them a horizontal plane of symmetry, then you could use the pattern or mold on either side.
Dave
Old 08-26-2012, 11:35 AM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Would something like these work? Relatively cheap and save hours of fabbing...
https://www.pegasusautoracing.com/gr...oupID=DUCTNACA
What are you using them for and how large do they need to be?
Dan Horton on this forum is expert, might ask him.
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 08-26-2012, 12:55 PM
DanH's Avatar
DanH DanH is offline
You can make an opening with a jigsaw. Fabrication of a practical air inlet requires more information. To what does the inlet lead? Have you sized them based on any particular requirement or operating theory? Do they need to seal to anything?
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-26-2012, 02:44 PM
DonFromTX's Avatar
Sorry, not enough information given. The right side will intake to the oil cooler and combustion air, thru a 3 inch hose that splits. The left (pilot side) one will cool the plugs and injectors, not much flow needed on that side. The right side will probably need all the air I can cram in there, the more the merrier..
See my kitlog link below, look at 8/13 for a photo of where the air goes on the right side.
Old 08-26-2012, 03:32 PM
DanH's Avatar
Sounds like you are talking about openings which lead to scat hoses, much like Jerry linked, but perhaps not NACA inlet shapes. Building them is easy; pink foam forms to make the duct transitions:
http://www.vansairforce.com/communit...ad.php?t=44856
The transitions would be bonded to the inside of the cowl. You only need one template to define the shape of the duct transition base, which would be their footprint on the inside of the cowl. Just flip the template for the opposite side. The footprint template is also the shape of the cut opening. The opening and the duct are faired together with a radius. Done.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-26-2012, 06:35 PM
DonFromTX's Avatar
Lots of good ideas there, thanks for the link. I can handle the layup and stuff, my big question is how to make them look like each other. I started out thinking that if I make one, it will work for both sides, but due to the compound curve that don't work at all.
My hope was someone had an idea of how to make both of them the same shape, an artist I am not.
Old 08-26-2012, 06:54 PM
curtis's Avatar
curtis curtis is offline
The image below is how I made my intersection fairings (copied idea out of a Van's rvator newsletter). The grid gives you visual reference from side to side when shaping the clay or foam.
RV-6A Slider
550 hours +
Build it light and cheap
