Old 08-25-2012, 11:56 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default AveoMaxx 6 in 1 help
I splurged for these fancy landing and taxi lights. They come with no instructions, I did find wire diagrams on line. A couple things I need help with;
1. How do you adjust them. It odes not seem obvious to me but without instructions it is difficult to determine this.
2. How did you mount them in the wing cut out?
It looks like they can be mounted to the part of the cut out that faces outboard, but the unit is long enough it seems it will have to recess in to the other side of the cut out (fwd facing section). Pictures or link to a builder log would be a great help.
Cheers.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 08-26-2012, 08:17 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Pictures
Send me your real email address and I'll send you some pictures later. I have the 6 in 1's in my 7. Work great BTW.
ktlkrn@cox.net
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 08-26-2012, 09:01 AM
RVG8tor's Avatar
Default Email sent
ktlkrn@cox.net
Just sent off the email, thanks for the help.
Cheers
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 03-06-2013, 01:45 PM
izzybear's Avatar
izzybear izzybear is offline
Default So how do you like them?
Mike, I am wondering how you like your Aveomaxx 6 in 1 lights? I looked around your build site for install pictures, but haven't found them yet?? Looking forward to seeing the post-paint pictures when Grady gets done!! Congrats!
Jim
RV-8 N223GT (reserved)
Finish - arrived 10/7/15
Fuselage - arrived 3/14/14
Wings - arrived 3/7/13
Builder # 83331
www.mykitlog.com/izzybear
VAF Dues gladly paid up till December 2020
"The ultimate responsibility of the pilot is to fulfill the dreams of the countless millions of earthbound ancestors who could only stare skyward and wish." - Unknown
Old 03-07-2013, 11:14 AM
RVG8tor's Avatar
Default Love them
Jim,
I love the lights, they were very easy to install and provide great lighting. Mine are wired for taxi or landing but not both on at the same time. This is due to me wiring thing before I decided to install the Aveo lights. I will add the dual function at a later date.
With this said they provide good light. The taxi lights with a wider field of view are a better anti-collision light in my opinion. I confirmed this while on along final with tower. I switched between landing a taxi on a long straight in and they said the taxi light showed better than the focused landing light, obviously having both on would be the best of both worlds.
I only have 3 night flights so far. One locally before I left to take the plane to Grady, I figured I might need to land at night on the trip, turns out I had two night landings on the trip. The first one was in Winslow well after sunset and a dark night and not much in the way of ambient light at the airport, I had no problem landing or judging height. Personally at night I am not looking at the runway as much as I am using the runway edge lights. I had to taxi at this airport with no diagram (unexpected stop) and I had never been there, I had no problems.
When I fly during the day I keep the taxi light on and I have had people tell me how bright the lights look, they are expecting a business jet when they see me on final.
I hope this help. The price is up there but the quality and ease of installation were big pluses for me.
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 03-07-2013, 11:19 AM
RVG8tor's Avatar
Default Log entry for install
Jim,
Here is the log entry, look plus or minus a few days. At the end of my build I was putting everything under "Final Assembly" the wing lights would be better under the "Wings" category.
http://www.mykitlog.com/users/displa...=155122&row=40
Cheers
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 03-07-2013, 12:09 PM
bkthomps bkthomps is offline
you may be a month early, aveo is releasing at sun n fun a drop in wingtip insert for the RV series that will fit out of the box, i believe it will be based on the 6 n 1
Old 03-07-2013, 01:17 PM
izzybear's Avatar
Default Thanks!
Thanks so much for the pirep on the AveoMaxx, Mike, I really appreciate it! And yes, I spent the last hour perusing your build site since I couldn't stop at just "plus or minus a few days"
Wire this, plug in that, make this piece...boy I guess that's what 90% complete and 90% to go means! I can't think about all those things at this stage in the build or I would go crazy! Looks like a great job on your end though!!
So if I understand, you set up one side "landing light" as the taxi light and the other side is set up as the landing light? Or do you have other lights besides the 2 wingtip "landing" lights??
Thanks again!
Originally Posted by RVG8tor View Post
Jim,
Jim
Builder # 83331
Old 03-07-2013, 01:20 PM
izzybear's Avatar
Default Good to know...
Thanks Brian, I was planning on checking them out at SnF, but enhancements are even better!
Jim
Builder # 83331
Old 03-07-2013, 01:25 PM
RV7Guy's Avatar
Default 6 in 1's
I have these and love them as noted above. I believe there are some changes coming to AVEO. The website shows the 6 in 1's but they are not shown in the "store" section.
I have my taxi and landing lights on at the same time. No reason not to. They are LED's and draw minimal power. Also, don't have the wear and tear each time they are turned on.
These are the brightest I've seen!!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
EMS Bell 407,
