Old 08-25-2012, 03:35 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default Gear leg cost?
I am trying to price out some surplus stuff I might want to sell, including a couple of -6a gear legs. I've checked the "List" and accessory catalog and plans to no avail. The plans just call them "Round gear leg" on DWG C2
Any ideas? I would call Van's, but it's the weekend...
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 08-26-2012, 09:46 AM
jrs14855 jrs14855 is offline
Default gear legs
Wittman gear legs from Aircraft Spruce are around $800.
Old 08-26-2012, 10:37 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up Archived
The internet remembers most stuff...
From "the List" in June 2001
U-601-LX BEND/GRND/XLE.DRILLED $165.00
Same price for both taildragger and nosegear main gear legs.
http://web.archive.org/web/200106020...blic/parts.txt
Drawing 45 gives them the U-601 or U-601A reference.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-26-2012, 11:21 AM
Thanks Gil! That really helps...
Jerry Cochran
Sherwood, Oregon
Mark Twain
Old 08-26-2012, 11:54 AM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
I purchased new 7 gear legs in June for $300 ea.
I believe the new 7A gear legs were $260.
Send me a PM if you want the prices when I sold my used mains & nose gear.
I gave the buyers a very good price.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 08-26-2012, 04:19 PM
Greg Arehart's Avatar
If you buy the legs as part of the engine mount "package" the cost is about $450 for the pair (above the cost of the engine mount only). In the package you also get some attach hardware.
New gear legs from Langaire are about $300 each and come unpainted. I think Vans sells them for a similar amount, but powder coated.
Greg
Greg Arehart
N 7965A
Old 08-26-2012, 04:47 PM
az_gila's Avatar
Exclamation
A word of caution though...
IIRC the early -6(x) legs were undrilled at the fus. end.
Van then provided them drilled, but I think they were match drilled to their mount and may not be interchangeable.
Later -6(x) ones may be better like the interchangeable nose gear legs.
Mine were match drilled and have a serial number etched on them.
Gil Alexander
Old 08-26-2012, 07:21 PM
This is true. I ran into this issue with my used mount & new gear legs.
Prior to 10/2004, they were match drill & paired to the mount.
After 10/2004, they were jig drilled to match all legs to the mount.
My drilled gear legs were toed out. I was able to correct them by drilling from AN5 to AN6. Spinning the gear into the mount and reshaping the top engine mount hole to accomodate.
If your gear legs are drilled, make sure the buyer is aware there may be a matching alignment issue.
1190+ hours
2019 Donation Paid
