View Poll Results: During a routine oil change which of the following do you comply with?
Only cut filter open and inspect sump screen
42 |
46.15% |
Only use Spectrometric oil analysis program (SOAP)
4 |
4.40% |
Use both methods
37 |
40.66% |
Only change oil, no further inspections
8 |
8.79% |
08-25-2012, 03:34 PM
Poll: Task accomplished during an oil change
1. Only cut filter open and inspect sump screen
2. Only use Spectrometric oil analysis program (SOAP)
3. Use both methods
4. Only change oil, no further inspections
08-25-2012, 04:56 PM
I cut the filter, but usually only inspect the sump screen every 2nd oil change (i.e. at annual since I generally only fly enough for two oil changes per year anymore)
Neal Howard
Airplaneless once again...
08-25-2012, 05:35 PM
Why not look?
Can't find anything unless you look for it.
08-25-2012, 05:36 PM
no filter, pull top dome oil screen
I also only do the suction screen at 25 hours or two years ( same thing).
I really have to wonder who designed the screen, housing etc.
Le Marquis deSade?
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
08-25-2012, 07:02 PM
i only do the suction screen a couple times a year. perhaps every 100 hours. I tihnk I am dropping oil analysis. The last report showed elevated iron but by then the cam and 3 lifters were spalled. 150$ a year for the fire dept to call and let you know your house is fully engulfed. pass.
Byron
1977 Mooney 201
Houston, TX
08-25-2012, 08:38 PM
Oil analysis a year ago showed everything normal, as in unchanged for 9 years. But, oil filter inspection showed lots of $$ needed. The engine absolutely would have shut itself down at some point (crankshaft gear chewing itself away). I haven't decided if I'll resume the oil analyses or not.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
08-26-2012, 05:17 AM
Originally Posted by AlexPeterson
Oil analysis a year ago showed everything normal,........
Maybe this would be another good poll to start? How may times did the filter inspection and how many times the SOAP accurately predict impending failure of a compnent.
08-26-2012, 06:13 AM
I recommend oil changes every 25 hrs and oil/filter at 50 hrs. Sump screens normally at annual unless something is found in the filter.
Cutting open the filter is a messy but absolutely necessary job, it will give you a heads up on an impeding failure so you MUST do it!
I'm not a big fan of oil analysis, filter inpections are very effective.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
