Old 07-04-2006, 04:10 PM
sjose45 sjose45 is offline
Default Access RV-9 under forward top skin F-7106
Looking at the RV-9 preview plans. DWG 28 shows the forward top skin F-7106 riveted on. What is the best way to gain access back in that area (between F-601, and F-7105) later?
S. Jose C.
Old 07-04-2006, 06:54 PM
ClayR_9A's Avatar
ClayR_9A ClayR_9A is offline
Default it depends...
What do you plan on putting there? Maybe you won't need any access.
I'd suggest not putting anything there, and not cutting an access hole in the top skin if you can help it.
If you are going to put something there, design it so that can easily be removed, and include long service loops so anything electronic can be hooked up on the floor, then pushed back up into place.
Just remember.. whatever you put there, you'll need to access it on your back in the most uncomfortable position ever.
Clay R- RV9A - Flying since 2004 - 400 hours
VAF dues paid through end of 2020.
Old 07-04-2006, 08:00 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
With a seat out, a blanket to soften & cover the seat/spar hump, and a couple of pillows up front, it's almost comphy enough to fall asleep!
Getting back out, sucks though! That's where those welded on handles to the roll bar really become worth the trouble of putting them on!
L.Adamson 6A
Old 07-04-2006, 08:52 PM
Build9A's Avatar
Build9A Build9A is offline
Default rvproject.com
Check out Dan's site at www.rvproject.com
He put an access panel up front, maybe two. take care. Jack
RV9A N489JE - Flying
Eagle Neck Airpark
Shellmans Bluff, Georgia
