There are many versions of start procedures that work for some people most of the time, but once you know how the fuel system works, you soon realise there is one system that works every time.
This is not my original idea either, but I will take the credit
Cold Start
WOT, FULL RICH
Boost pump, on and as soon as the pressure gets to 20PSI or more count "One Thousand Two Thousand" and pump off.
Mixture ICO.
Throttle cracked enough to give you 1200 RPM.
Crank!
Hot start, Do nothing! Crack throttle the same, crank, as soon as it coughs, run the mixture up.
AFTER START - BOTH CASES
Lean until the RPM peaks, then ever so slightly starts to fall again. Taxi like this.
Runups done same setting at 1700 or so RPM, and richen ONLY enough to keep it smooth, no more. Watch EGT's all rise on each mag, if they dont, and one falls, you will know which plug! Cycle the prop ONCE!!
Return mixture to the leanest possible again before lining up.
Line up procedure....Pump on, Mixture rich......ROLL!
If your procedures are not like this, change!
This does EVERYTHING it should.....And NOTHING it shouldn't!
This works on all IO Lycomings, totally different on TCM/CMI
