08-22-2012, 12:33 PM
Electric aileron Trim
I am building an RV-7A and have decided to put in the electric trim for the aileron. I bought from Van's the kit that puts the servo in the aileron and
controls a tab off the back of the left aileron. The drawing that came with
the kit is hard to read and lacks some details. Does anyone have photos of there project or maybe a source of more detailed info?
Steve.
08-22-2012, 02:39 PM
Interesting, the aileron trim option for the 7/7A is not the tab version that was sold for the 6/6A.
Are you sure you have the right kit?
Vans Link for Aileron Trim
Jason Hess
N777JH - Reserved
RV-7 - Builders Log Tail complete, wings nearly done, starting fuselage!
RV Factory - Complete sans floor coating, Slideshow Here
People are not excellent because they achieve great things; they achieve great things because they choose to be excellent.
Gerald G. Probst, Beloved Grandfather, WWII B-24 Pilot, Successful Businessman
08-22-2012, 04:00 PM
You are not restricted to the spring system and the aileron trim has been done by other RV 7 and 8 builders. I have talked with builders who did the spring bias system and they did not like the feel it created with the stick.
I have already put in the trim for the elevator and will use a hat switch to control both. I know it will work fine. It's just that the instructions are not very detailed on how to trim some of the parts.
08-22-2012, 04:06 PM
Agreed as I have flown a 6 that has the 7 spring bias setup in it. Just wondered if you had inadvertently ordered the wrong kit. Appears not.
I "think" the trim kit was an after thought so that may explain the lack of direction/clarity/Clear Plans. Good luck. I am sure someone will pipe up and help you out.
Jason Hess
N777JH - Reserved
08-22-2012, 04:44 PM
I prefer the aileron servo/ tab setup that I put in the 6. Installed mine on the outboard end of the right aileron. Figured it would offset a bit of pilot weight, as I put the auto-pilot servo out there too. I worked great. I know someone who built two 9's with the bias springs. He prefers my aileron tab setup (the same kit you bought).
08-22-2012, 10:49 PM
I have some build pictures on my site..
Go to my kitlog site and select all, then select ailerons and then go to 10/27/2010 and start looking and reading about my install. Larry helped me understand how to get it done. You are right, the instructions leave a lot to be desired. I had access to my spar so adding the doubler plate and cutting the spar opening was easy. I believe the RV-7 Aileron is made a little differently than the RV6 so I don't know for sure if you can retrofit it. I think you can.
http://www.mykitlog.com/users/index....ng&project=665
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
08-22-2012, 11:00 PM
Thanks Wendell. The photo gave me an idea of the set up
08-23-2012, 05:28 AM
I've been thinking about doing what Pat Hatch described in this thread. Looks so much more elegant than the trailing tab.
- John
08-23-2012, 06:00 AM
Lot's of em...
check out my website on jurgenroeland.brinkster.net
go to 'empenage kit' and then 'elevator' and 'elevator trim attachment' article.
also check 'finish elevators', it may be a good idea for you as well if you have the electric trim to make an extra bushing hole in the rear spar of the elevator for passthrough of the electric wiring. Vans tells you to pass the electric wires AND the threaded pushrod through the same bushing. As you may already have figured out yourself, this is not a very clever idea as the electric wire may rub chafe against the rod and wear out. bad idea...
greetz
J.
