Old 08-22-2012, 07:09 AM
High_Flyer's Avatar
High_Flyer High_Flyer is offline
Default Dynon pitot on a safair1 mast
Hi everyone,
This may seem like a stupid beginner's question and I guess it is...
I am in France and used to the metric system. Understanding the anglo-saxon measure system is like learning a new language for me. I have managed to figure out rivets sizes etc, but with screws and bolts there is a new measure which is threads per inch... There are screws, machine screws, metal work screws, etc. Same for bolts.
Could anyone point me to some sort of "guide" to understand the different screws and bolts, and which one to use for our kits.
Another related question: I am installing a dynon pitot on a safeair1 mast. The screws required to atach the pitot to the mast are not included in the pitot kit. I see that some have used 6-32 screws for this. However I have f... up one of the holes and would like to go to one size above 6-32. So what scew is just one size above 6-32 that would work fine for my pitot installation? Also what tap to use to make the thread in the pitot?
Thanks and sorry for what may seem like a very basic question to some...
Alain.
RV7 (F-PRVZ), Tip Up, Aerosport IO-375, Dynon Skyview, VP-X, Day VFR.
Flying since June 2017.
Old 08-22-2012, 01:21 PM
RV9A Bill RV9A Bill is offline
Default Next size
A #8-32 is what many of us commonly use as next size up. It will work fine
With the dynon pitot and safe air mast.
RV9A Bill
Old 08-22-2012, 02:25 PM
randyintejas's Avatar
randyintejas randyintejas is offline
"However I have f... up one of the holes"
Ha! I love this! yep I F..up one of the holes myself and then F.. it up again! Got so sick of F..up the hole that I stuck a dang pop rivet in it!
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
Old 08-23-2012, 09:41 AM
High_Flyer's Avatar
Ok Gents, thanks a lot for the replies.
After I posted the above I went in search of a solution nearby and found some nice screws, drill and tap, all in metric to finish mounting the pitot on the mast. I guess it will be the only place on the airplane with metric scews. I'll have to make a special note in case I need to replace them one day.
Good day to everyone.
Alain.
Old 08-24-2012, 12:33 AM
Flying Scotsman Flying Scotsman is offline
Aaaahhh...not quite I found at least two other locations:
There's a metric stud on the Skytec starter, and the Andair fuel pump (and I think the fuel valve, too) uses metric hardware.
There was one other place, IIRC, but I can't think of what it was at the moment. No doubt this will bother me until I remember it in the middle of the night tonight
Steve "Flying Scotsman"
Santa Clarita, CA
PP-ASEL, ASES, Instrument Airplane
RV-7A N660WS flying!
#8,000
Old 08-24-2012, 09:00 AM
bruceh's Avatar
bruceh bruceh is offline
Those cool little semi circle type switch guards like these:
They have metric threads. I lost one of the tiny nylock nuts that come with these and had a fun time finding replacements here.
Also have metric bolts on the Odyssey battery lugs.
Bruce Hill
2020 VAF donator
Old 08-24-2012, 11:23 AM
paul mosher
Posts: n/a
Default hardware guide
Try this http://www.mechanicsupport.com/AN_bolts.html
Old 08-27-2012, 09:46 AM
High_Flyer's Avatar
Default Thanks
Originally Posted by paul mosher View Post
Thanks a lot for the link. I'll have a look.
