Old 08-21-2012, 03:37 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Default Dynon SkyView 4.0 Ships!
To all our SkyView customers, SkyView software version 4.0 is now available.
4.0 Adds:
Basemap: Roads, rivers, cities, railroads, etc. This is a free database, available worldwide in high resolution.
Greatly enhanced mapping visuals: Graphics that match the style and color of sectional type charts. This includes shaded, dashed and other airspace depictions, greatly enhancing in-flight awareness. European airspace details have been added to reflect all airspace categories.
Check out the new map:
AHRS Cross-Checking: Multiple AHRS units are now constantly cross-checked in the background and will alert the user if they do not agree. The user is then presented with a simple display of both attitude solutions so they can choose the correct one.
Enhanced Network redundancy: The system now utilizes a fully redundant power and data network between the SkyView screens and modules. This prevents almost all single wire failures from causing a loss of data.
Visit the download link here: http://www.dynonavionics.com/docs/su...e_SkyView.html
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 08-21-2012, 03:41 PM
bkthomps bkthomps is offline
great news!
Old 08-21-2012, 03:47 PM
2bolts 2bolts is offline
Default Looks very pretty
But might it be getting a little 'cluttered' for something that might be just 7 or 10 inches big? Might well increase head in cockpit time....never a good idea IMO, but will be easier to use than a map.
Roger
A Brit in Texas
RV8 N886LH (Reserved) BuNo 83320
Collecting books/info/tools.
Tail kit arrived! 9/30/2012
Construction started
"The engine's overheating, and so am I! Either we stand down, or blow up! Now which do you want?" Sqn Ldr Canfield.
Old 08-21-2012, 03:59 PM
Anything you don't care to see on the map can be turned off, which can help clutter enormously.
Here's a sectional of the same area. You can see it's not exactly easy to read! You can see how much easier the restricted area is to see on our map (orange, up top)
Dynon Avionics
425-402-0433
Old 08-21-2012, 05:27 PM
scard's Avatar
scard scard is offline
Originally Posted by dynonsupport View Post
4.0 Adds:
Sorry, I'm still chuckling about that . What does that look like?
Scott Card
CMW E-Lift
VAF Advertiser
Old 08-21-2012, 06:27 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Can you set the degree to which they must disagree before you are notified? I'm sure that two different AHRS units will come up with slightly different readings and there must be some epsilon that would be exceeded before notification would be necessary. What are those epsilon values?
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
Old 08-21-2012, 07:39 PM
The user gets a warning that says "AHRS CROSS-CHECK ERROR: PITCH". They can then press a button, which will display both AHRS solutions side by side. The user can press "disable" on the AHRS that they no longer want in the system.
You cannot set the disagreement ranges yourself. We have chosen values that we believe are reasonable to catch AHRS units that are in serious disagreement without giving nuisance alarms. Each term (G-meter, pitch, roll, heading, airspeed, etc) has a different difference based on our data. There is more processing going on as well besides just simple differences.
Dynon Avionics
425-402-0433
Old 08-21-2012, 08:19 PM
I take your point, but in my defence I did say I thought it would be better than a map
Roger
A Brit in Texas
Old 08-21-2012, 09:32 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
if you are in the soup and the ahrs cross check warning comes up...how do you know which is correct?
Ryan Allen, CFI
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 98%, Working on Finishing Kit, AEIO-540 on the stand
Acro Sport 2 on deck.
Old 08-21-2012, 09:55 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Look at your third attitude source, or engage your independent autopilot and see which one agrees at that point!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
