If they were indeed accurate at one time, the bend in the float must be OK. I'd look for something common between the tanks since it would be unusal for the both of them to fail/change the same way.
Is there a grounding problem? You could disconnect the gauges from the senders and place different value resistors across the input and see what readings you get. This will let you know if the gauges are OK. Though, I suspect they are.
Tony
RV8A
N97AP
Warner Robins, GA
Phase I complete
