Old 08-18-2012, 10:59 PM
BJohnson's Avatar
BJohnson BJohnson is offline
Default PMA5000EX without an external dimmer question
Question for those of you with PS Engineering audio panels. If I don't want to use an external dimmer, the instructions say to connect pin 6 or 7 (depending on the system voltage) to either pin 8 or 9 on the J2 connector. This will set the back light to a constant level. But the LED in the buttons will dim with the photocell. I cannot find anywhere that states whether pin 6 or pin 7 is used for the 14V system. Which one is it? My guess is pin 6 but I cannot find a discrete callout anywhere. Also, There is no mention of connecting a ground to pin 5. Is this correct, no ground to pin 5 for the constant backlight option?
Finally, is the constant backlight setting too bright at night that a dimmer would be recommended?
Brice
RV-9A 90897 FLYING
