Old 07-03-2006, 09:34 AM
briand's Avatar
briand briand is offline
Default Acrylic Wing Insp. Plates
Anyone consider replacing the alum. ones with plexi-glass? I was thinking about doing this on the outbaord one that provides access to the aileron bellcranks so you can inspect the linkage during each preflight.
Old 07-03-2006, 01:36 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Toucy Feely
I learned during my helicopter flying days that inspections are nearly equally divided be touching a feeling a part and a visual inspection.
Clear plates will let you know everything is attached but my interest is insuring that no end play has developed in the linkages. Also that the fasteners are tight and not just attached.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 07-03-2006, 02:05 PM
brules brules is offline
Banned
briand, those aluminum covers are on the tension side of the lifting wing and provide strength to the skin. I believe thats why there are so many screws holding that cover on. Be on the safe side and call Vans tech help before you change those covers out.
Old 07-03-2006, 03:22 PM
William Slaughter's Avatar
William Slaughter William Slaughter is offline
I recently called Van's because the ready made inspection plates on my RV-8QB were 0.025 instead of the specified 0.032 material. Van's couldn't explain this discrepancy, but the engineer consulted said that he would "feel better about it" if all of the inspection plates were 0.032. They sent me four new 0.032 blanks at no charge. It seems that they may well be a structural element of the wing skin.
William Slaughter
Houston, TX
RV-8QB
Old 07-03-2006, 03:32 PM
briand's Avatar
Structural issues aside, I think you should be able to visually detect some excess free-play in the linkage by moving the ail. up and down while looking through the "window".
Old 07-03-2006, 10:59 PM
Banned
structural issues aside, the pushrod ends that you want to see through your acrilic window will be located at the upper surface of the wing above the main pushrod connected to the stick. It will be dark in there as well as obstructed view. the window idea sounds good but in practice is impractical. you would have to lay on your back on the ramp to look up into the wing and that dosen't even sound fun. just a note; that area where that bellcrank is located is the terminus of the fuel tank splice to the nose skin and the splice of the main skins and that area has a hole located there that needs that aluminum plate to hold it all together. this is just a museing but the inpection window you suggest should be on the top of the wing, this would eliminate all the afore mentioned problems.
