I know there is a ton of threads on performance, but everyone is posting numbers at WOT at 8k ft, etc. I wanted to see if what I am seeing in my plane is normal or below average because I am wondering if I am having a drag issue somewhere that is also a possible cause for my heavy wing. Also the only numbers I have right now are IAS, wasn't thinking of TAS, but I will update everything after I fly next. I also wasn't planning on getting this thread going so I haven't done any official testing, just something I was thinking about this morning.
Also, I need to go around to all the fiber glassing on my plane and make it better, all stuff I planned on doing before I get it painted. Toward the end of the build I was in just get it done mode. I know I can probably gain a few kts from cleaning up the fiberglass
Anyway, here is what I am seeing. I have an O-360, 180 hp, FP sensenich prop, the one that Vans recommends for this setup. I have trouble getting WOT numbers because if I go WOT in level flight my RPM will creep above redline.
So far what I've been seeing with all fairings on is at about 4000 feet, I am indicating 170 mph ( ~150 kts) at 65% power. 75% can yield up to 180 mph (~156 kts). Now I know this is IAS and there are errors, next flight I plan on climbing to 8k ft and getting TAS numbers to compare with the specs on Van's website. But what is everyone else with a similar setup indicating at these power settings? Is it normal that WOT level flight puts me over red line, and yes I know buying a CS prop will solve that problem
Thanks for the input everyone
