Old 08-15-2012, 12:56 PM
dougweil's Avatar
dougweil dougweil is offline
Default Crack in VS attach plate
Hi all:
Our local FBO was doing an inspection on an RV-9A and found this crack in the vertical stab attach plate (F-781 on my RV-7... could be F-981 on the 9A). I know nothing else about it and I am not familiar with this aircraft. Just thought I would share the photo. It might be a wise inspection item to include in a condition inspection.
Note sure about the elongated holes either.
Doug Weiler
Hudson, WI
president, Twin Cities RV Builders Group
RV-4, sold
RV-7 completed and flying N722DW, 930 hours
Based Lake Elmo, MN (21D)
Old 08-15-2012, 02:32 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default ??
Larry, why would you assume this? Something I'm
missing? This is now the second post of a similar
crack discovery in the same general area. Something Vans
should be looking into?
Al Girard, Newport, RI
N339AG
RV-9
Old 08-15-2012, 02:35 PM
terrykohler terrykohler is offline
Default Just started my Condition Inspection
Originally Posted by LARCO View Post
Good post Doug. This looks like someone designed their own version of a very important piece using the wrong metal. If that happened I ask WHY do people do this? Larry
I'm going to take a close look in this area as I recently had to leave 3TP tied down thru some pretty heavy storms passing thru Killeen, Tx. Wind was strong enough to break my rudder gust lock and slam the rudder into the elevator. From the picture, how can you tell this is the wrong metal?
Terry
Old 08-15-2012, 03:04 PM
868RM 868RM is offline
Default crack
Is there a crack in the mating part up about 1/4 in. and to the left?
Old 08-15-2012, 03:08 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
I would look at it and say that the bend is a little too high and the back of the part - the radius of the bend - was resting on the sharp edge of the vertical stab spar...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-15-2012, 03:24 PM
AlexPeterson's Avatar
Good eye, sure looks like one.
Alex Peterson
RV6A N66AP 1750+ hours
KADC, Wadena, MN
Old 08-15-2012, 03:58 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
Here is a link to one other report of cracking in this part:
http://www.vansairforce.com/communit...ad.php?t=87124
Note that in that case the crack was through one of the bolt holes. Like the case discussed in this thread, the crack originated at the perimeter of the part at the apex of a concave angle.
So far as I know, in neither of the reported cases was there any indication that the part was other than as supplied by Vans.
Thanks, Bob K.
Bob Kuykendall
Low-drag wingtips for RV-4 through RV-8
EAA Technical Counselor
Old 08-15-2012, 04:16 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Was all that paint chipped away as part of the inspection, or was it all chipped away already prior to being inspected? If the latter, then wouldn't that indicate some seriously abnormal vibration has been going on?
Neal Howard
Airplaneless once again...
Old 08-15-2012, 04:17 PM
Larco's Avatar
Larco Larco is offline
I made an incorrect statement earlier thinking of the 4/6/7/8 models sorry for assumption and wasted words. Larry
Old 08-15-2012, 04:44 PM
CRW CRW is offline
Doug,
When did the airplane go into service and how many hours are on it now?
Thanks for the information.
Best regards,
Chuck
