Try this:
Purchase rubber grommets that will push on to the shank of your rivet. You may have to slice them in half to ensure that they stand proud of the rivet shank a little bit. The friction of the grommet will hold it in place.
When you buck the rivet, the bucking bar will compress the grommet and force the faying surfaces together. Give it a bit of a hit with the rivet gun so that the rivet swells and clamps the faying surfaces together. Remove the grommet and finish riveting.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
