  #41
Old 11-26-2012, 02:46 PM
DCat22's Avatar
DCat22 DCat22 is offline
Originally Posted by smiller View Post
I hadn't thought about it before, but I think getting some jump/parachuting instruction is a great idea. Some 30 years ago I did it just for fun. There have no doubt been lots of changes in the field since then, but I remember some interesting lessons.
+1
Even with only two tandem for-fun jumps, I looked at the chute while doing some acro training differently afterwards. I think I'd much more efficient about the whole process with the under 'chute having been an experience vs. only a mental idea of what will happen.
-Rick Greer, VAF #2492
Old 11-26-2012, 03:58 PM
wera710's Avatar
wera710 wera710 is offline
I?ll take a Stab at some of the original questions, mainly because I?ve had a chance to experiment with various chute types, helmet/headset types and fly an RV-8.
On the WHY? Simple. Stuff happens. So if you are an adventurous pilot who likes flying 3 feet from others, it could save you. If you are a really adventurous one who likes to do 20 minute acro sessions that require you to write down the sequence so you can remember it all, it?s also a good idea. One, confidence. Two, you can?t discount Geese, Buzzards, and morons in spam cans that seem to think your smoke trail is something they want to fly through.
On the chute type, Seat Cushion versus Back Pack question;
Seat Back Style: If your RV-8 is going to have the adjustable rudder pedals (honestly, you?d be smart to install them no matter what) you can get away with a Back Pack style chute. No matter what the manufacturer tells you, a Seat BACK style chute IS going to push you forward further than the standard seat back cushion from Vans. So you will feel a little cramped in that the instrument panel and windscreen bow will be closer to your than you are accustomed too. However, long term flight in the back pack chute is generally a non -issue. I have flown five or more, one hour hops with about a 30 to 45 minute rest between hops with no appreciable pain using this type of chute. In this case, it was a Para-Phenalia MINI. No pain. No discomfort. Nothing. Personally however, I did NOT like the back pack design in the RV-8 because I felt it really pushed me further forward than I like, but with adjustable pedals, it was not really a problem, leg wise. I am 5? 10 inches and needed to adjust the pedals forward a notch or so. Without adjustable pedals, forget it unless you are shall we say, vertically challenged. None-adjustable pedals may mean you may not be able to use a seat back type. Borrow one first to find out. In my case, the chute was used mostly for close formation flight, and it repositioned me so that the windscreen bow was dead in the middle of my line of sight to the lead aircraft I was formatting on, particularly from the number Two position. No so bad if off his right wing. So if you plan on doing that sort of thing, you need to consider seating position and site lines when deciding which way to go between seat pack or seat cushion types. Best advice. BORROW both and find out. On the upside, I think it would be very easy to get out of the RV-8 using this type of chute as there is nothing hanging down below you. When you ?rise? to clear the cockpit (roll, fall, whatever) the chute is rising with your back and clears the seat back as you egress. This IS important. If you gotta get out, a back pack design may be a lot easier to egress the RV than a seat cushion pack.
Seat Cushion Style: The seat cushion types (Strong Mod 304 etc.) is wonderful in as much as it does not screw with your site lines. You remove your seat bottom, and put a 1 inch thick by 6 inch wide by 14 inch long piece of hard foam in the seat pan (which is used to keep the chute pack level). When you climb in, you now have the same seat height as you would have had with the seat cushion in place. Your fore and aft sight lines remain the same as well, so there is no need to readjust your head position constantly due to the windscreen bow being in the way. The DOWN SIDE of the seat bottom type is that it?s like sitting on a briquette. Worse, in the RV, you cannot use a thick cushion on top of the chute because there is not enough head clearance. You can order padding from Strong, but height is critical in the RVs. So you have to test the concept before spending $$ on a seat pad you cannot ultimately use. If you do not level the chute with a filler pad beneath it , you might be able to get away with some sort of pad on top of the chute. The concern then becomes that the chute is angled too steeply at the front and cuts off leg circulation. I have about 20 hours sitting on these suckers for formation flights and even with the aforementioned 40 minute break between hops, you are in agony after about three or four hours. I also wonder if egress will be as simple with the seat bottom type. Probably not, but its one more thing hanging down inside as you bail. However, several war bird guys have used the Strong 304 and 306 models to actually save their keister?s when it hit the fan. I recommend reviewing the Big Beautiful Doll youtube video on just how quickly it can go bad and how low you can be and still survive with a Low Porosity canopy. When the pilot parted ways he had 500 to 600 feet left to impact. The canopy popped, he swung once, and was on the ground! They WORK! Finally, if you are not flying hard core hops like mentioned above, the seat bottom type is comfortable enough for a typical session of sky busting.
Personally, for ease of egress and comfort, I want to say stick to the seat BACK design in the RV-8. Naturally, being and idiot, I insisted on buying the seat bottom type due to the sight lines. I do more formation than acro of late and it annoyed me to no end being so forward in the cockpit.
On Helmets. Love them or hate them, IF you are going to use one, you SHOULD look into a quick disconnect plug: part number U-92A/U which is also part MS177/3-1. This allows you separate your helmet from the headset cables in a HURRY. You simply have to splice it inline a few inches down the line from the helmet proper. You then rewire the remaining long lead on the jack/radio side to a TP-120 plug, which plugs into the U-92A/U on the helmet side. Rather than having to reach down and find your headset jacks to pull the mic and speaker plugs, you just tug on the central plug (the TP-120) going into the U-92A/U adapter and off you go. Why bother? I have heard several stories of folks trying to bail only to be yanked back in by their lead wires. The Adapter gives you a break away point even if you forget. Of course, a headset is a different story. Those you can toss. But a helmet is not coming off should you need to leave the premise quickly.
As far is wearing a lid, I seldom do for anything but acro sequences or tight formation. But I can tell you if you are doing a lot of formation in clear whether, that visor is an EYEBALL saver, or maybe even a life saver. Using sunglasses and a visor, you can look straight up at the leader while the conniving, mean spirited, foul rat B****rd positions you so that you are staring right into the sun for 367,921 seconds or the end of time, whichever comes first! Without it, wow, PAIN. So people may want to laugh at you for wearing one, but you kept position and did not hit anyone else?s aircraft for being blinded! Nice to have coming over the top of a loop into the sun as well.
Canopy release. Enough covered here. But there are plenty of methods to get the RV-8 lid to part ways. That?s the least of your worries.
Scott "Lawbreaker" (yeah, its a fair cop!)
RV-8 N710PX "Bad Attitude!"
Old 11-27-2012, 07:09 AM
Tim Fitzpatrick's Avatar
Tim Fitzpatrick Tim Fitzpatrick is offline
Default Butler makes a great rig
I use a Butler seat cushion type in the front and use a Butler back pack for the back seat. Butler is I believe the only dedicated emergency parachute manufacturer in the states. They do not make sport rigs. Their front seat cushion style that I have does not require any additional foam to fit correctly in the front seat. It is custom made for the RV-8 and will fit perfectly. They sent me a back pack style when I was building to see if I wanted that. I did not like how it pushed me forward. I have 300 sport parachute jumps and preferred a back pack style however I ended up going with the seat cushion style. Look around test some different set ups and pick what is best for you, good luck
Tim Fitzpatrick,
LCDR USCG (Ret)
CWO2-US Army, CPL-USMCR
ATP-H, C MEL/SEL, CFII Helo/SEL, ATC Spec, D-6779
RV-8A, N308TF (Flying 255+ Hours)
Author "The Mortal Horseman"
Amazon.com
Old 11-27-2012, 07:51 AM
dealfair dealfair is offline
Paul, I know a guy from Georgia who's -4 canopy departed cleanly, but denting the fin in the process. He'd forgotten to latch it properly. I got the story after asking him what had happened to dent the fin at a fly-in.
Best,
Yep, I have first hand knowledge about the -4 canopy departing. Explosive bolts could not have done a better job. It made just the smallest bump on my HS. I had protective tape on the leading edge; cut the tape but did not harm the metal at all. I failed to latch the canopy.
Can also state it is REALLY windy w/o a canopy. I had trouble keeping my upper lip from covering my eyeballs!!
Deal Fair
RV-4 (N34CB)
George West, TX (8T6)
Old 12-14-2013, 01:36 PM
Pittsartist Pittsartist is offline
In 4 days time it will be 2 years to the day since I had a fatal (to the other guy) mid air.
I guess you can figure out fairly easily which side of this debate i'm on.
Would you go boating without a life jacket ?.
drive a car without a seat belt ?
How many people have died because they were wearing a parachute ?.
etc ............
If you can, wear one. AND learn how to use it.
Old 12-14-2013, 03:22 PM
s10sakota's Avatar
s10sakota s10sakota is offline
"One, confidence. Two, you can?t discount Geese, Buzzards, and morons in spam cans that seem to think your smoke trail is something they want to fly through.
On the chute type, Seat Cushion versus Back Pack question"
Just for a second, let's check our egos at the door and be honest. There's more "morons" flying RVs than any other type airplane out there. Ive never seen a Piper Warrior do a high speed pass down the runway. I've also never seen a Cessna do an overhead break in the pattern. In fact, I've never heard of a spam can pilot ever even consider wearing a parachute because those pilots don't fly their airplanes in ways that the thought of wearing a parachute would even apply!
Don't believe me? Just search some RV videos on YouTube or attend a fly-in. See which airplanes are doing the fly-bys, hot dog maneuvers, and over-head breaks.
Having said that, when my RV is complete, I will wear a flight suit and a helmet for safety reasons. But I won't be the moron walking around all day at the fly-in still wearing a military green flight suit full of patches.
Mark Pensenstadler
1962 Piper Cherokee 160
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
2019 KITFOX Super Sport
Old 12-14-2013, 03:27 PM
ronschreck's Avatar
ronschreck ronschreck is offline
You seem to imply that the overhead pattern is illegal or unsafe. Can you elaborate?
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 12-14-2013, 03:33 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Before this gets out of hand, let me point out that "name calling" is pretty uncivil Mark, When you have to resort to calling others derogatory names, it usually means you have already lost your argument.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-14-2013, 03:34 PM
s10sakota's Avatar
Are you doing the overhead break over your home airfield out in the country? Go for it! Nothing unsafe about it at all.
Or, are you doing it at the uncontrolled airport during a flyin where 100% of the other pilots (including the newer not-so-inexperienced pilots) are all doing the standard pattern entries? Yes, then in my opinion it becomes unsafe because everyone else knows where to look for other airplanes entering or even leaving the pattern.
Then here comes the RV guys doing the "non-standard" pattern entry screaming in at 180 kts doing something that is out of the norm. Is the overhead break unsafe? No, does it become unsafe when it's not the norm for the given day or situation? Absolutely.
There was a fly-in write up recently on another forums, my forums in fact (RANS CLAN.com) where the RVs did everything non standard and really threw a wrench in the system.
I'll see if I can find the post...
Mark Pensenstadler
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
Old 12-14-2013, 03:36 PM
s10sakota's Avatar
Paul, you might want to read the previous posts. The word "moron" was used as a direct reference to the word used by another to describe the spam can pilots.
Mark Pensenstadler
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
