Old 08-13-2012, 06:07 PM
Michael Burbidge Michael Burbidge is offline
Default Installing Van's manifold pressure transducer...
I'm installing the Van's manifold pressure gauge. I bought the transducer and the install kit.
I'm looking for information on installing the transducer. I looked through the archives but couldn't find anything.
It looks like the way it works, is that you drill a hole in the firewall, and mount the fitting that adapts the aeroquip hose to the pvc hose directly on the firewall. The pvc side sticks through the firewall into the cabin.
The transducer should be mounted somewhere behind the panel on the cabin side of the firewall. The aeroquip hose goes from the restricter attached to the #3 cylinder to the adapter fitting on the firewall.
Does that sound correct?
The thing that is confusing me is that naive thinking that somehow the third port on the transducer manifold should be involved.
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 08-14-2012, 07:41 AM
Rupester Rupester is offline
Yessir ... you've got it right. Be aware the little barb fitting on the cabin side of the fitting requires VERY small tubing, smaller than you can get in Tygon at your local hdwe store. Because I needed MP pressure at both the sender and my Lightspeed brainbox, I tee'd the vacuum tubing from that little clear tube that Vans provides. Finding a tee that accomodated that small tubing on one branch was quite a search.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 08-14-2012, 07:45 AM
Default OOps
I meant to add that the third port on the transducer may be a way to send MP to another device (like a Lightspeed!) without doing the tee thing like I did. (FYI ... my transducer was furnished by GRT and did not have a third port. Other than that, it's just like the one that Vans provides)
Terry Ruprecht
