Old 08-12-2012, 10:06 PM
KRviator's Avatar
KRviator KRviator is offline
Default O320-H2AD Engine Mount Mod
G'day all,
I've got an O320-H2AD in the shed to hang on my -9A, but, I've got standard Dynafocal-1 mount. No major drama's there, the local welding guru can modify the mount for me, but he's after a couple of photo's of what people have done previously as a guide.
There's plenty of people with this donk, but every photo I've seen thus far appears to be the Vans-provided H2AD mount, I can't fine one that's been locally modified. So, for those with H2AD's who've modified their standard Van's mounts, could you post a photo, or flick one through on email?
Ta muchly.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 08-13-2012, 06:20 AM
Alschief Alschief is offline
Default H2AD Mount
We did one locally.
I will have look for pics.
It is not pretty but is functional and strong.
AL & Brenda Smith
RV12, UL Power N495BA Flying
RV6 N495AB Sold
KEOS Neosho, MO
alsmith@olemac.net
alsmith@ulpower.com
Old 08-14-2012, 05:19 PM
KRviator's Avatar
Thanks for that. No great rush, but it'll save me sending my mount back across the Pacific to swap for a factory H2AD mount.
Old 08-14-2012, 06:56 PM
339A's Avatar
339A 339A is offline
Default New 4130 Tube
Back across the Pacific, I didn't want to send mine across a couple states!
Really not much to it. The only thing that has to change is the crossover tube at the top. The accessory case is different on the H, and the tube needs more bend in it. I just ordered another piece of 4130 tube, found a good welder who cut and fit the new tube in.
You should be able to judge it, by holding the mount up to the engine, that's all we did. Been on my 9A for 1110 hours now...
Regards,
Scott Mills, Front Range, CO
N339A - 1900 Hours!! since 9/11/05
Like Us on Facebook: https://www.facebook.com/ScottandDeb...tures/timeline
Airport Landings
"In order to discover new lands one must have the courage to lose sight of the shore." Andre Gide
"Never feel sorry for a man who owns a plane" Charles Morse (Anthony Hopkins) in The Edge
Old 08-20-2012, 06:38 PM
KRviator's Avatar
That's what Ive done to figure out where I need to build n the new tube, but the welding guru is chasing some photos if possible to show what others have done before.
Old 08-26-2012, 04:38 PM
KRviator's Avatar
And just to follow up, I touched base with The Mothership and was in turn referred to a very helpful chap at the contractor that actually makes the RV-9 engine mounts. So, for the princely sum of $65 US, plus shipping, you can get a factory-bent tube that will (hopefully) exactly match the existing mount.
All you then need to do is hold your newfound tube up to your existing mount, mark the tubes to cut and once you've removed them, weld the new one in. Easy as falling off a log. Not that I've ever fallen off a log, though...I'll get some photos of the tube when it arrives and the resulting modified mount shortly.
So, if anyone else needs to follow this route, the person to contact is Steve at Super-12.com. And a big thanks also Goes to Daryl S at Vans for your help too.
