Old 07-02-2006, 11:16 AM
AX-O's Avatar
AX-O AX-O is offline
Default oops rivet question.
I have not use these rivets yet, however would like to know if after you drill a bad rivet out and the hole is enlarged (because you are not perfect). Do you try to re-dimple the hole? For example if I have an AN426AD3-4 rivet and enlarge the hole, I would then go to a NAS 1097AD4-4, right? But now the hole is not round. After drilling the hole with a #30, would I try to re-dimple the hole and if so with a #30 or a #40 dimple die?
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 07-02-2006, 11:23 AM
Paul Eastham's Avatar
Paul Eastham Paul Eastham is offline
No, the oops rivet should work with the existing dimple, and the hole drilled out to #30.
Order a selection of oops rivets from Van's so you'll have the right length handy when the inevitable happens...
Also, if the hole is only a little bit oversized, you can try pre-swelling a normal rivet in your hand squeezer to fit the hole, then rivet normally.
Good luck,
Paul
Paul Eastham - Mountain View CA
RV-9A standard build, flying! ~300 hrs
EAA Chapter 338 San Jose
Old 07-02-2006, 11:43 AM
AX-O's Avatar
Thanks, I ordered a few different ones from Vans last Fri.
Axel
