Old 07-02-2006, 11:11 AM
N722SH N722SH is offline
Default Bumb Question - Upper/Lower Spar Flange Bars
After much delay, I am finally getting around to counter sinking all the holes in the wing spar flanges. (BTW - I?m building a ?9) The instructions say to ??mark the orientation of the spar?and study the plans until you understand how the spars are installed. You do NOT want to build a wing upside down!? Well, after studying the plans and staring at the spar for a while, I ?understand? how the spar is installed, but don?t ?understand? how the spar was built!
While ?studying? the spar and plans, I noticed that the upper and lower spar flange bars (the thick stepped bars that run along the top and bottom of the forward side of the wing spars, W-906 B & D) are in the opposite position from what I would expect. The bottom flange bar is shorter and gets thinner sooner than the top flange bar. This is counter intuitive from what I would expect - at least to me! I would think the longer and thicker flange bar would be on the bottom (bottom of the spar loaded in tension) with the shorter and thinner bar (loaded in compression) on the top.
Anyone else noticed this? I?m just a ?dumb? engineer, but what am I missing here?
Scott Harding
RV-9 ? Slowing working on wings
Sugar Land, TX
Old 07-02-2006, 03:15 PM
mlw450802's Avatar
mlw450802 mlw450802 is offline
Scott Harding
Sugar Land, TX
Perhaps the design consideration is for buckling, not yield. Tensile and compressive yield stresses are very similar and if that were the only design criterion, both top and bottom would likely be the same.
-mike
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
Old 07-02-2006, 09:43 PM
Default Question about Upper/Lower Spar Flange Bars
I thought about that, but the rivets and plate nuts go in the spar flange, which is on the aft side of the spar web - the side opposite the spar flange bars. The bars don't interfere with the riveting/bucking of the wing skins and are inside/beneath the tank skins.
Scott
Old 07-03-2006, 05:50 AM
mlw450802's Avatar
Scott
Just in case you thought I misspoke, I meant classical column buckling (i.e. Euler or Johnson type as appropriate), not rivet bucking.
-mike
Michael L Wilson
VAF# 148
Payson, AZ
Old 07-03-2006, 07:27 AM
Default Its buckling not bucking
-mike
Mike,
You are right, I did miss read your original post - Sorry.
I do think you are correct that the larger upper spar flange bar is to prevent Buckling. I have no desire to "re-engineer" the airplane, but wondered if anyone out there in RV land with experience in wing structures had an explanation for the difference in size of the upper and lower spar flange bars beyond the obvious.
Thanks - Scott
