08-10-2012, 02:27 PM
Pirep on heated Dynon pitot icing?
Hi all,
Starting on my wings, I'm most likely going to buy the Dynon heated pitot tube. Reading back through some old threads from years back, there were mentions that some people still had the tube ice over, even with heat, and even after multiple replacements by Dynon. I was wondering if this is still a problem as of late? For reference, my flight profile for needing pitot heat is very light icing / minimal IMC on midwest Ohio (Cincinnati) winter days where it's mostly clear, maybe freezing fog / mist. Nothing really bad. I know better than to fly in anything worse.
The Dynon tube still looks to be the most cost-effective, and if I happen to use a Skyview, AOA's already there. I'm leaning towards AFS, so I'll just cap the AOA tube in that case. But better to cover as many possibilities as I can.
Thanks for any "refreshers" on whether this is still an issue, if it would even apply to my light freeze conditions or not, etc.
Scott Balmos - RV-9A N112SB
Cincinnati, OH, KHAO
08-10-2012, 05:28 PM
Keep in mind that for experimental ab flight into known icing is prohibited...
Dave & Trina
RV-9A Flying  - 330 Hrs. Painted  Finishing the interior.
08-11-2012, 07:26 AM
My heated pitot works well, even when "inadvertently flown into moderate plus icing" and that's all I want to say about that.
Actually... It was not me.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
08-11-2012, 12:17 PM
I have one, and it gets warm when tested on the ground. You raise an interesting point, does it get hot enough in flight? I haven't tested it in icing.
I'd suggest you run a line for the AOA port. While I have a GRT for my main EFIS I have a Dynon D6 for a back up, and I like its audio AOA alert.
08-11-2012, 04:20 PM
So how hot should it be?
Well don't know but, on certified aircraft it will melt the vinyl pitot cover if left on, on the ground. Ask me how I know.
I remember doing a quick turn around in a Brittan Norman Islander about 30 years ago with the aircraft all shut down (just) and master off and an annoying passenger decided to hang his lazy hand from my pitot while jawing away to his friend. Last time he ever did that! Ouch!
Clearly, only ?warm? is not considered enough in the certified world.
Gerry.
08-11-2012, 06:22 PM
You are a cunning old devil
The Dynon heater ramps up to maintain a warm temperature regardless of outside air temperature.
The old certified style needed to be just as warm at well below freezing so the heat generated is constant and thus really hot on the ground.
David Brown
08-11-2012, 06:36 PM
I used a SS Falcon heated pitot from ACS and I bet it gets over 500F drawing about 8A. Simple on or off and watch my efis amp reading for conformation.
Good judgment comes from experience, and a lot of that comes from bad judgment.
08-11-2012, 06:46 PM
The Dynon unit has a temperature sensor and adjust current to keep a constant temp.
Ralph Finch
RV-9A QB-SA
Davis, CA
08-11-2012, 07:17 PM
Wayne, are you sure it wasn't a Gerz? My Dynon pitot is metal. When I said it got warm in the hangar, I only had it on long enough to test it. So I don't know what its setpoint is.
08-11-2012, 08:08 PM
You probably saw my posts of having it ice over multiple times even after replacement. In my non expert opinion there are a couple of possible problems, the opening is too wide and lets in too much moisture, the drain hole is too small or the heat may not be up to it keeping it clear. I had it plug up even without airframe icing. It usually happens when OAT is very cold. I replaced it with a used certified heated tube and have not had any more problems.
Floyd Packard
bought flying RV7a (Roberta's)
Kennewick WA
New pilot, learning and loving it!
