Old 08-10-2012, 10:38 AM
Jurgen Amtmann Jurgen Amtmann is offline
Default snorkel to cool alternator
Can anyone tell me where I can find the small snorkel that goes into the cooling air inlet, then connects to a hose that blows cooling air over the alternator?
Jurgen Amtmann RV-6
Old 08-10-2012, 10:56 AM
krw5927 krw5927 is offline
Jurgen Amtmann RV-6
I Jurgen,
Darrell Reiley (LifeofReiley on VAF) used to have some aluminum flanges for sale for 3/4" tubing which were perfect for this sort of application. Send him a PM, he may still have some left.
Kurt W.
RV9A
FLYING!!!
Old 08-11-2012, 10:15 AM
billnaz's Avatar
billnaz billnaz is offline
Default Corrugated ducting works
I used the black plastic ducting left over from wing wiring. Just drill a hole sized to capture the ducting in the air inlet ramp, and direct the duct at the alt., or mags too, zip tie the other end to anything convenient in the area.
Bill Grischo, Gilbert AZ
N911WG RV-6A DVT
Flying, thinking about polishing
Old 08-11-2012, 05:10 PM
pkill's Avatar
pkill pkill is offline
Hello Jurgen,
I used some SCAT-4 Ducting and Aluminum Flanges from ACS both on the inlet for the alternator blast tube and on the back of the baffles for tubes to each mag.
Flange 1” p/n 10350-4
http://www.aircraftspruce.com/catalo...uctflanges.php
SCAT-4 1” Ducting p/n 05-29904
http://www.aircraftspruce.com/catalog/appages/scat.php
pk
Old 08-11-2012, 06:26 PM
guccidude1 guccidude1 is offline
As stated above, use the corrigated tubing left over from wiring. Located the cooling tube on the right coloing intake,above the alternator, secure with rtv and wire ties. There is sufficient air pressure available to adequately cool the diode pack at the rear of the alternator. Dan
