07-02-2006, 12:50 AM
vertical oil filter + breather tube
Hi all,
I've got a vertical oil filter adapter on my O-320. The theory is that it makes for drip-free filter changes by poking a hole in it and letting it drain into the sump. It's also nice to have lots of room between the engine and firewall.
Only problem is that it places the oil filter almost directly behind the breather outlet, so the standard routing for the breather tube that goes aft and straight down the firewall won't work. Looks like it will have to go left and down a bit, then down and inboard perhaps clamped to the engine mount.
Has anyone already figured out a simple solution and appropriate parts for this, or am I breaking new ground here?
Paul
07-02-2006, 10:36 AM
Use a rubber hose
Hi Paul,
I had the same issue. I bought a rubber hose at napa that solved the problem. I'll post photos when I am done hanging the prop today. Darwin Barrie helped me with this same issue a few months ago.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
07-05-2006, 03:26 PM
Yes, please post pictures. I messed with it a bit, but still haven't figured out the best route. Using the straight part of the NAPA hose I can sort of make it work, but I'll have to bend the Al tube as well to get the outlet over the exhaust.
Dave
07-05-2006, 11:07 PM
Pics Finally
Pete
St. Paul, MN
07-05-2006, 11:18 PM
Thanks for posting the pictures, Pete. Was this marked as a radiator hose, or something else? Did it come with a bend in it, or just straight?
Paul
07-05-2006, 11:30 PM
Hi Paul,
I too have a vertical (well, 45 deg from vertical) oil filter. I used fuel/oil hose from AS&S to do what Pete did (9/16", 5/8", can't remember). However, I had extra - if you want to try it out, feel free to pick it up from my office.
07-05-2006, 11:48 PM
radiator hose
Paul,
It is a radiator hose - reinforced rubber - it did have a pre-formed bend. I don't have a part number or application. I picked it off a rack.
Pete
St. Paul, MN
07-06-2006, 05:27 AM
Does radiator hose react to engine oil??
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at you own risk.?
07-06-2006, 05:43 AM
Good Question
It is the same kind of hose vans puts in the FF kit. Builders here report you will want to watch it for "gumminess" and change every few years.
Pete
St. Paul, MN
07-06-2006, 10:30 PM
In my automotive experience, radiator hose will soften and expand slightly with prolonged exposure to engine oil. By "prolonged", I'm talking about several years.
As petehowell said, keep an eye on it, and change it every couple-three years. It's cheap enough...
Ken
Helicopter mechanic (A&P)
USAFR KC-10 Boom Operator, on final approach to retirement
My RV-9/8/7 dream may be on life support, but it ain't dead yet!
