Old 07-01-2006, 10:21 PM
apatti apatti is offline
Default Bench Grinders
My Ryobi brand (Home Depot) bench grinder is dying after only 2 years or so of not so much use. Two questions:
1) Are they worth repairing? I have to give it a good spin or two before it will finally "catch" and slowly come up to speed. Do bench grinders have startup capacitors. Sounds like this could be my problem.
2) Assuming the answer to number 1 is a no, what brands/size are you running that you would recommend? Where did you buy it?
Tony
RV8A
N97AP
Warner Robins, GA
Phase I complete
Old 07-02-2006, 06:36 AM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Some two-handed advice
Harry Truman wanted to meet a one-handed economist (...on the other hand..). Now I will be guilty of same. Sorry, Harry.
My dad had a hardware store in a working class area near the Detroit auto plants. He sold Lufkin tools (the best at the time). He always told his customers only the rich can afford to buy cheap tools. They usually took his advice.
On the other hand, I have a Delta grinder that cost about $25 on sale and it's doing the job of occasional work in the RV shop. I've had it about 3 years. I would do it again.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 07-02-2006, 06:51 AM
PJSeipel PJSeipel is offline
I have two of the Harbor Freight $35 model, one with a lamp, one without. I prefer the one with the lamp, it works much better (stronger) than the one without even though the motors are rated the same. I do, however have to give the wheel a spin before I turn it on or it doesn't go. It's probably cheaper to buy a new one than to try and fix it.
PJ
Old 07-02-2006, 06:22 PM
RV_7A RV_7A is offline
Highly recommend...
Best motor for deburring with a 3M Scothcbrite wheel you can get for the money.
http://www.harborfreight.com/cpi/cta...emnumber=40668
-Jeff
www.JeffsRV-7A.com
N808TX
Old 11-20-2008, 05:03 PM
Adam Oke's Avatar
Adam Oke Adam Oke is offline
Anyone else have any issues with the Ryobi Bench Grinder Model: BGH616 ?
It's on sale starting tomorrow for 3 days for $20 CAD at Home Depot.
For $20 I don't think you can go wrong, even if it breaks in 2 years. What do you think? Go for it?
Edit: Heck ... I just noticed it has a 2-year warranty.
Adam D. Oke
Old 11-20-2008, 07:30 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I built my whole airplane using one of those little Ryobis - bought it in a pinch, figured it was cheap enough to replace when I needed a "real" one....still using it for everything 4.5 years later!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-20-2008, 08:18 PM
Adam Oke's Avatar
Beauty! Just what I wanted to hear. Looks like I'll buy it tomorrow then. My Isham Kit is in the mail and I'm starting to take over the basement rec. room!
Adam D. Oke
Old 11-20-2008, 08:50 PM
borislav borislav is offline
I have the same one and it works fine. The problem is, all that stuff around the wheels really gets in the way. I removed the glass shields and work rests and flipped the lights to the back, but the metal guards are not removable and significantly limit access for deburring large or odd-shaped pieces on the scotch brite wheels.
I ended up putting the stone wheels back on the grinder and getting one of these for deburring:
http://www.harborfreight.com/cpi/cta...emnumber=94393
Access is a million times better, and I wear safety glasses.
Boris Deianov
-7 wings
Mountain View, CA
Old 11-21-2008, 08:22 AM
danielhv's Avatar
danielhv danielhv is offline
For ~$50 you should just replace it and move on. Just my .02.
Old 11-21-2008, 09:05 AM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Bench grinder repair
I have been using a "El cheapo" bench grinder for the last 25 years. It has been used to build 2 RV's and has failed on two occasions.
1. The push/pull on off switch stopped working. Solution: remove the switch, re-bend the contacts.
2. The grinder wouldn't start without spinning it first (made buzzing sound when turned on). The cause of was the centrifugal switch wasn't working. This switch disconnects the capacitor once the grinder is up to a certain RPM. The capacitor is only used during start-up of the motor.
Solution: Remove the side of the case and re-bend the contracts on the centrifugal switch. Takes about 5 minutes to perform this operation.
My bet is that your centrifugal switch contacts aren't working. Try to fix this yourself, if all else fails buy a new one.
I have a bought a replacement grinder just in case mine were to die on me after all these years. The new grinder has been sitting in its box for the past 8 years.
Good luck.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
