Old 08-08-2012, 09:46 AM
Stewie Stewie is offline
Default Wire run behind fuel tank: safe?
Hi all-
I am running VOR coax and LED strobe/nav wiring from my RV4 wingtip through bushings on the forward side of the spar. These join up with the safeair aoa/pitot plastic tubing near the bellcrank, and I plan to run this as a bundle in the space between the fuel tank and spar into the fuse. There are no exposed wires or quick disconnects in the area behind the tank. I am curious if others have done this and if it would be considered safe/unsafe to run wiring behind the tank like this. I'd like to keep things simple and light, so I'd prefer not to use conduit if I can safely do so.
On a related note, I have SW fuel senders in the wings, so obviously in that case at least there is a wire in direct proximity to the fuel tank.
(I did search the forums on this but was not able to find any info. Not sure how other RVs are built so the moderator can feel free to move this to the RV4 forum if that would be more appropriate.)
Eric
Eric Stewart
=VAF= dues paid 2016
facebook.com/TheSR1Project
Old 08-08-2012, 12:10 PM
Av8torTom's Avatar
Default Brackets
Not familiar with the 4 but are there Z brackets holding the tank to the front of the spar? If so, how will you get through those? Any reason why you can't run your wires behind the spar?
N677AT reserved
Superior XP O-320, 160HP
Old 08-08-2012, 12:42 PM
rv7charlie rv7charlie is offline
No Z brackets in a -4.
I wouldn't worry about the VOR coax at all. If your strobe & nav are both LED (no actual high voltage pulses to fire a strobe tube) I probably wouldn't worry too much about those, either. That assumes that you can be confident that they won't ever move enough to wear through the insulation (operating with the pessimistic assumption that the tanks *will* leak someday).
Charlie
Old 08-08-2012, 01:18 PM
RV6_flyer's Avatar
Originally Posted by Stewie View Post
Hi all-
Eric
Eric:
The -6 and -4 both have the same mounting. Neither use the "Z" brackets that are on the later RVs.
It is safe to run your wires between the main wing spar and the tank on the -4 or -6(A).
I have been flying my -6 almost 15-years and over 2,600 flight hours just like you are talking about. Nav on one side and the power wire to my strobe power supply on the other. (other side meaning top and bottom so that they are away from each other) Yes I have two power supplies for the wing strobes. No strobe noise in the electrical system with the power supply mounted on the front side of the spare out near the wing tip.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-08-2012, 01:59 PM
Sid Lambert Sid Lambert is offline
Just tie them up nice so the screws won't rub on the wire but you should be good. You can get some fuel sitting on top of the lower spar flange if you overfill or have a gasket leak so try to keep the wire higher than lower.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 08-08-2012, 04:36 PM
Mel's Avatar
Mel Mel is offline
Default No problem at all!
Literally thousands of RVs have been flying for decades wired just like this.
Build on!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-09-2012, 08:26 AM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Voltage not the issue..
Charlie
Don't let voltage be your guide.... You can weld with 6 volts until the wire melts!!
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 08-09-2012, 08:53 AM
Default Thank you!
HI all-
Thanks for your input. Glad to hear this is an accepted and safe method for running wires. VAF is a fantastic resource.
Eric
Eric Stewart
Old 08-09-2012, 02:39 PM
You want to maybe give that a little thought (in context), & see if you stick by the statement?
Charlie
